In my discourse plugin’s folder discourse-adplugin/assets/discourse/helpers/
I’ve created a file with helper
discourse-adplugin/assets/discourse/helpers/eq.js.es6
import { registerHelper } from 'discourse/lib/helpers';
var makeBoundHelper = Ember.HTMLBars.makeBoundHelper;
registerHelper('insert_ad', makeBoundHelper(function(params) {
var dfp_top_3_display = Discourse.SiteSettings.dfp_top_3_display;
if (dfp_top_3_display < 0) return false;
return params[0] == dfp_top_3_display;
I’m using this helper in template, in development environment it works well but in docker production it produces an error:
Uncaught Error: Could not find module 'discourse/lib/helpers' imported from 'discourse/plugins/discourse-adplugin/discourse/helpers/eq'
What is the right way to create template helpers in plugin?
