Plugin working locally But not in live
The discussion revolves around a plugin that works locally but fails in production due to serializer patching issues. vinothkannans initially faced problems with the unread_post field not appearing in the latest.json response on the live site, despite the plugin working locally. The issue was resolved by patching TopicListItemSerializer instead of ListableTopicSerializer, as the latter didn’t apply correctly in production. sam and david explain that this discrepancy likely stems from caching or class loading differences between development and production environments, particularly related to eager loading or class reloading. david notes that using the add_to_serializer API instead of direct class modifications resolves the issue, referencing a recent fix in Discourse’s plugin API that addresses such inconsistencies.
Continuing the discussion from Timeline - Social Network like News Feed UI in Topic List:
My above plugin working perfectly on localhost as it in screenshots. But I can’t see any updates in live website.
Looks like below code is not working. I am not getting unread_post field in latest.json response.
I can see the plugin name in both plugins list and upgrade pages.
I just fixed it myself :slight_smile:
What was wrong? :bug:
@sam TopicListItemSerializer is inherited class of ListableTopicSerializer. If I monkey patch ListableTopicSerializer it is not working on live version. Instead if I monkey patch TopicListItemSerializer it is working on both local and live. Weird :flushed:
wow, strange, maybe the serializer was being patched too late in the process after it already cached certain data.
Yes. I think so. May be eager_load or cache_classes doing that part.
I just spent a long time debugging an issue caused by this. I was doing
add_to_serializer(:admin_user, :somefield)...
which worked fine in development, but not in production. Changing it to :admin_detailed_user fixed the problem (admin_detailed_user inherits from admin_user).
It would be good if we can either fix this, or at least add a warning. Differences between dev/prod are painful!
100% in agreement here :heart: if you can figure out any way to make this explode consistently on both prod and dev it would be awesome… My guess is that this is somehow related to the reloaders.
One sad thing about relying on “reload” magic is that there is a lot of magic. Its one big reason we moved away from using sprockets (and never jumped on the spring train) … it just got too hard to fit the mold of reloading without side effects.
(this could be not reload related, but hey, its a nice story :crazy_face: )
Ich bin gerade wieder auf dieses Problem gestoßen und bin auf dieses Thema gestoßen. Es sieht so aus, als hätte @sam eine Korrektur für die Plugin-API hinzugefügt, die dieses Problem behebt :smiley:
Also, um das abzuschließen: Wenn du auf dieses Problem stößt, stelle sicher, dass du die add_to_serializer-API verwendest, anstatt die Klasse selbst zu ändern.
