On the latest version of Discourse on Docker I’m having the reverse of this issue: Polls disabled caused 500 error
If polls are enabled replying to a topic shows a 500 error. Trace:
NoMethodError in PostsController#create
undefined method `polls' for #<Post:0x00007fa2b3502050>
Extracted source (around line #431):
#429 else
#430 match = matched_attribute_method(method.to_s)
*431 match ? attribute_missing(match, *args, &block) : super
#432 end
#433 end
#434
Extracted source (around line #552):
#550
#551 unless post.is_first_post?
*552 polls = ActiveModel::ArraySerializer.new(post.polls, each_serializer: PollSerializer, root: false, scope: guardian).as_json
#553 post.publish_message!("/polls/#{post.topic_id}", post_id: post.id, polls: polls)
#554 end
#555 end
Extracted source (around line #326):
#324 def on(event_name, &block)
#325 DiscourseEvent.on(event_name) do |*args|
*326 block.call(*args) if enabled?
#327 end
#328 end
#329
Rails.root: /src
Application Trace
lib/plugin/instance.rb:326:in `block in on'
lib/discourse_event.rb:14:in `block in trigger'
lib/discourse_event.rb:13:in `trigger'
lib/post_creator.rb:239:in `trigger_after_events'
lib/post_creator.rb:208:in `create'
lib/new_post_manager.rb:271:in `perform_create_post'
lib/new_post_manager.rb:209:in `perform'
app/controllers/posts_controller.rb:179:in `create'
lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
config/initializers/100-quiet_logger.rb:18:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/missing_avatars.rb:23:in `call'
lib/middleware/turbo_dev.rb:34:in `call'
Framework Trace
activemodel (6.0.1) lib/active_model/attribute_methods.rb:431:in `method_missing'
plugins/poll/plugin.rb:552:in `block (2 levels) in activate!'
/usr/local/lib/ruby/2.6.0/set.rb:338:in `each_key'
/usr/local/lib/ruby/2.6.0/set.rb:338:in `each'
actionpack (6.0.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.0.1) lib/abstract_controller/base.rb:196:in `process_action'
actionpack (6.0.1) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.0.1) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.0.1) lib/active_support/callbacks.rb:135:in `run_callbacks'
actionpack (6.0.1) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.0.1) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.0.1) lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport (6.0.1) lib/active_support/notifications.rb:180:in `block in instrument'
activesupport (6.0.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.0.1) lib/active_support/notifications.rb:180:in `instrument'
actionpack (6.0.1) lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack (6.0.1) lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord (6.0.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.0.1) lib/abstract_controller/base.rb:136:in `process'
actionview (6.0.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.0.1) lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
actionpack (6.0.1) lib/action_controller/metal.rb:191:in `dispatch'
actionpack (6.0.1) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (6.0.1) lib/action_dispatch/routing/route_set.rb:51:in `dispatch'
actionpack (6.0.1) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.0.1) lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack (6.0.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.0.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.0.1) lib/action_dispatch/routing/route_set.rb:837:in `call'
rack (2.0.8) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.0.8) lib/rack/conditional_get.rb:38:in `call'
rack (2.0.8) lib/rack/head.rb:12:in `call'
rack (2.0.8) lib/rack/session/abstract/id.rb:259:in `context'
rack (2.0.8) lib/rack/session/abstract/id.rb:253:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/cookies.rb:648:in `call'
activerecord (6.0.1) lib/active_record/migration.rb:567:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.0.1) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (6.0.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.7.1) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.0.1) lib/rails/rack/logger.rb:38:in `call_app'
railties (6.0.1) lib/rails/rack/logger.rb:28:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/request_id.rb:27:in `call'
rack (2.0.8) lib/rack/method_override.rb:22:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/static.rb:126:in `call'
rack (2.0.8) lib/rack/sendfile.rb:111:in `call'
actionpack (6.0.1) lib/action_dispatch/middleware/host_authorization.rb:83:in `call'
rack-mini-profiler (2.0.1) lib/mini_profiler/profiler.rb:312:in `call'
message_bus (2.2.4) lib/message_bus/rack/middleware.rb:57:in `call'
railties (6.0.1) lib/rails/engine.rb:526:in `call'
railties (6.0.1) lib/rails/railtie.rb:190:in `public_send'
railties (6.0.1) lib/rails/railtie.rb:190:in `method_missing'
rack (2.0.8) lib/rack/urlmap.rb:68:in `block in call'
rack (2.0.8) lib/rack/urlmap.rb:53:in `each'
rack (2.0.8) lib/rack/urlmap.rb:53:in `call'
unicorn (5.5.4) lib/unicorn/http_server.rb:605:in `process_client'
unicorn (5.5.4) lib/unicorn/http_server.rb:700:in `worker_loop'
unicorn (5.5.4) lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
unicorn (5.5.4) lib/unicorn/http_server.rb:144:in `start'
unicorn (5.5.4) bin/unicorn:128:in `<top (required)>'
bin/unicorn:87:in `load'
bin/unicorn:87:in `block in <main>'
bin/unicorn:86:in `fork'
bin/unicorn:86:in `<main>'
Full Trace
