kjain
                (Kunal Jain)
                    November 30, 2015,  5:39am
              1
              When I am trying to post a new question, the pop ups are becoming unreadable as the top bar is hiding what they are saying on the top, hence breaking user interface. Here are a couple of screenshots highlighting the problem:
or look at this picture:
In both the pictures, it is invisible what the box was saying on the top.
              The problem was reported a while ago here
    I am constantly struggling with the “Your topic is similar to…” popup which on my screen disappears off the top of the window, behind the header. See the screenshot below. While I appreciate the helper text, it interferes with my browsing of the site while writing and has me fiddling with text size or making the composer window smaller until the X shows up so I can close it!
My request is to move the X button down to the bottom right corner of the blue popup so that I can quickly dismiss it.
