Possible to add comment count (to a Ghost blog)?
The discussion revolves around integrating a comment count feature from Discourse into a Ghost blog. stromfeldt inquires about accessing a topic’s comment count to display on their Ghost blog’s front page. jomaxro points to a relevant thread on embedding Discourse comments via JavaScript. stromfeldt later shares a solution using a script created by Vikas Potluri, available on GitHub, which can be seen in action on their blog. ahmadabdolsaheb expresses gratitude and seeks further assistance in implementing the embed as a button with a URL to Discourse.
I just integrated Discourse into a Ghost blog I recently started up and am using the Eston theme. By default Eston is set up to use Disqus, which comes with the possibility to add a widget of the comment count at the bottom of the post preview (or wherever, really) as such:
comment count
As I’m using Discourse instead of Disqus, would it be possible to similarly access a topic’s comment count so that I could integrate it into my Ghost blog using Eston?
See Embed Discourse comments on another website via Javascript, @codinghorror’s blog is on Ghost and embeds comments.
I’d already gotten Discourse embedded into Ghost a while ago (that was surprisingly easy!) and knowledge of @codinghorror’s integration was definitely a push in the right direction when I was deciding what to use with Ghost. My issue therefore isn’t about installation but rather about grabbing comment count numbers for the front page of the blog (where only excerpts of blog posts are shown, and Discourse isn’t even loaded). But if I gather correctly that the place to ask about this is over on that Embedding Discourse thread then I’ll do so. Thanks!
Sei riuscito a trovare una soluzione? Sono interessato anche io a quella funzionalità.
Ops, sono contento che tu l’abbia chiesto, perché sembra che abbia dimenticato di aggiungere un link alla “soluzione” creata per il mio blog. Lo script sviluppato da Vikas Potluri è disponibile su GitHub. Puoi trovare Vikas sul forum di Ghost se hai domande a riguardo (non chiedermelo a me, non sono in grado di fare quel tipo di programmazione). E se sei interessato, puoi vedere lo script in azione sul mio blog (trascurato per un po’, ma presto di nuovo attivo).
Grazie, apprezzo molto la tua risposta rapida.
Devo solo trovare un modo per trasformare l’embed in un pulsante con un link a Discourse.
