È possibile avere la scheda 'username' aperta di default invece delle notifiche?
Hi. I’d like to set up my Discourse site so that when a user clicks their profile icon, the default tab shown is the ‘username’ tab (i.e. the one with summary, activity, etc.) rather than the notifications one. Is there a way to do this?
Secondly to that, what’s the best option for removing or renaming some of the options in that tab? For example if I wanted the list to be simply “Activity | Messages | Settings | Log Out” and change ‘Preferences’ to ‘Settings’.
Thanks for any advice!
1 Mi Piace
Hey,
have you looked in:
Admin → customise → text
4 Mi Piace
Ah of course! That let me change the name anyway, which is a start. Thanks!
3 Mi Piace
If you want to make it easier to log out, I think you might add it to the hamburger menu. You can change those menus with theme components. If you want to remove things that’s pretty easy with CSS.
2 Mi Piace
