Which messed up the formatting of the post. Tabs, paragraph/image alignment, and a quick underline with CTRL+U similar to Microsoft Word would really make writing quick articles much less of a pain.
I am looking for other writing tools that I can import into Discourse. Because writing clear long article style post is just not really doable.
Understood, but Discourse is not meant to write articles. It’s a forum, not a blog
In some Discourse forums, articles are published on a dedicated WordPress blog which uses WP Discourse – WordPress plugin | WordPress.org.
This works for me. Also, why would you want to indent? virtually nobody has done indenting since online documents and text blocks became a thing. Text blocking looks better and is the contemporary standard for online publishing. Indenting even looks weird and there is a reason it isn’t easy to do in markdown formatting.
That code works until you add other code into the post then it breaks everything. If you want to recreate it, add 8 times for paragraph indents then add that code above. It changes the formatting on everything.
Book/manuscript formatting is definitely better than this web format style, especially for reading long articles. Blocks are helpful when a point comes for them.
My work around with Tumblr was to use blocks and many photos to break up the paragraphs. Since reading a lot of text with no indents is really not enjoyable.
I would recommend reading some of the Documentation topics. if you want to learn how to use markdown, html and other allowable formatting, this is a start:
<div data-theme-indent="indent">
Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam
</div>
Also, if you want to do some other formatting with images and alignment:
note: the indent function can apply to multiple blocks with a single click of the button. so you can type multiple paragraphs and then select all of them and indent all at once. [1]
btw, this component is meant to be demonstrative for how to make custom toolbar changes for css formatting - if you’re going to use this component, please fork it because i will likely not maintain it and archive it at a later date. ↩︎
as the footnote says, please fork it and do your own dev on it. i have no actual use for it and only made it to show you how to do these sort of customizations yourself.
You wouldn’t happen to know why I can’t change my Trust Level 4 @name anymore. I changed it to OFFICER, now I can’t find that word anywhere in the Site_Text. Its completely missing. Maybe it was always that name, but I think I changed it from Leader.
I think that’s the group title. I think it’s either the trust_level_4 automatic group’s title or the Leader badge’s. Check both, I can’t seem to remember which one it is.
