התמונה שפורסמה לא תוצג לאחר שהורדה ל-Discourse
סיכום מבוסס בינה מלאכותית
The issue is that when a remote image is downloaded to Discourse, it won’t be displayed. Canapin found that adding an empty line before the image code resolves the issue. Angus suggested that the problem lies in how Discourse handles HTML to Markdown conversion, but was unable to reproduce the issue. However, Canapin pointed out that the image isn’t displayed in Angus’s test link.
A solution was provided by Arkshine (via Canapin), which involves adding a blank space before any <img> tag using a PHP filter. This adds an empty space above the image code, which prevents Discourse from failing to display markdown downloaded images.
Hi!
I have some WP articles like this one: Et vous, vous avez appris vite ? - Monocycle.info
Which are sent on Discourse. At first, the remote image is correctly displayed on the Discourse post, but when the remote image is downloaded to Discourse, then it won’t show anymore: Et vous, vous avez appris vite ? - Actualités - Monocycle.info
Looking at the Discourse post’s code after the image has been retrieved to Discourse, it looks like this:
If I add an empty line before the image code, then it is correctly displayed:
Here’s the WP article’s code:
<!-- wp:paragraph -->
<p>Dans le cadre d'une recherche sur l'apprentissage du monocycle, Claudia Stehr et Klaas Bil s'intéressent au temps de l'apprentissage. Et pour cela, ils ont besoin d'un grand nombre de statistiques.</p>
<!-- /wp:paragraph -->
<p>Pour les aider, <a href="https://forms.gle/SEQtC6JQyw3tA7jv9">répondez à leur questionnaire</a> (version française) ! Si vous avez déjà répondu dans une autre langue, il ne faut pas doublonner. :)</p>
<!-- wp:image {"align":"center"} -->
<div class="wp-block-image"><figure class="aligncenter"><img src="https://lh5.googleusercontent.com/N8Qtu1XBr7hK4Wg3hkxiMWPdU9V_czUuNS8VjHVxWfnLlQTCKrlUM2QoWrt9Zd4iXeMceaX7sZSi_8J_dJhOAgpISIdLdjguoSY0ZfrjCoHs6KEfBrXmrJcKU7tsyGaIqQ=w650" alt="" title=""/></figure></div>
<!-- /wp:image -->
What happens exactly? Is that some sort of WP-Discourse / Markdown bug, or something else?
This is about how Discourse handles HTML to Markdown conversion (it’s not to do with WP Discourse). I tried to reproduce your issue, however the <img> tag is not being converted into a markdown image, and it’s displaying properly (including after post “cooking”).
https://try.thepavilion.io/t/html-image-markdown-test/985
Am I misunderstanding something? The image isn’t displayed in your link:
@Arkshine sent me this solution that adds an empty space before an image:
add_filter('wp_discourse_excerpt', [$this, 'wp_discourse_excerpt'], 10, 1);
 * Adds blank spaces above any <img> tag.
 * Purpose is to avoid Discourse failure to display markdown downloaded image.
 * @param $post_content
 * @return string
public function wp_discourse_excerpt($post_content)
    $post_content = preg_replace('/(<img\s)/i', "\n\n$1", $post_content);
    $post_content = preg_replace('/[\n]{3,}/', "\n\n", $post_content);
    return $post_content;
