Hi.how can I connect to postgres database and see the structure and tables in ubuntu terminal.I want to write a plugin but I don’t khow the database structures
Assuming you’re using our docker install:
./launcher enter app
rails db
If you’ve got a development environment set up, just rails db should do it.
          thank you but how can I see tables?and data bases
          Try the data Explorer plugin.
          Is site language saved in database?
where?
Changing the locale from the default English one creates a row in the site_settings table.
After changing it for example to German, the default_locale record is created:
