I’m having significant problems doing this upgrade too. Similar @Vaping_Community, I have postgres on a different mounted volume (/mnt/volume_tor1_01/shared/standalone).
I am getting this error
mv: cannot move '/shared/postgres_data' to '/shared/postgres_data_old': Device or resource busy
mv: inter-device move failed: '/shared/postgres_data_new' to '/shared/postgres_data/postgres_data_new'; unable to remove target: Directory not empty
Upgrade Complete
Optimizer statistics are not transferred by pg_upgrade.
Once you start the new server, consider running:
/usr/lib/postgresql/15/bin/vacuumdb --all --analyze-in-stages
Running this script will delete the old cluster's data files:
./delete_old_cluster.sh
UPGRADE OF POSTGRES COMPLETE
Old 13 database is stored at /shared/postgres_data_old
To complete the upgrade, rebuild again using:
./launcher rebuild app
My understanding is that the solution is to basically manually rename
postgres_data → postgres_data_old
postgres_new → postgres_data
then run ./launcher rebuild app. Seems simple enough, but when I rebuild, I still am stuck in the loop and end up with the following directories:
postgres_data_older
postgres_data_old (I think it becomes postgres_data_older)
postgres_data
postgres_data_new
It seems like for some reason it’s not recognizing that postgres_data has updated, tries to do it again, fails when trying to move the directory.
$ cat postgres_data/PG_VERSION
15
I tried the manual approach laid out in the OP but no luck either. Please help!
full log
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20250129-0720: Pulling from discourse/base
Digest: sha256:01b8516e5504c0e9bc3707773015ff4407be03a89154194ff3b5b8699291bc26
Status: Image is up to date for discourse/base:2.0.20250129-0720
docker.io/discourse/base:2.0.20250129-0720
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2025-02-23T11:41:32.477354 #1] INFO -- : Reading from stdin
I, [2025-02-23T11:41:32.504068 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2025-02-23T11:41:32.508552 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2025-02-23T11:41:32.513290 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2025-02-23T11:41:32.517671 #1] INFO -- : File > /root/install_postgres chmod: +x chown:
I, [2025-02-23T11:41:32.522244 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2025-02-23T11:41:32.523354 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/15/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.523912 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.524756 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.525365 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.526239 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.526873 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.527613 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.531734 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.532882 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/15/main/postgresql.conf
I, [2025-02-23T11:41:32.534021 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/15/main/pg_hba.conf
I, [2025-02-23T11:41:32.534342 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/15/main/pg_hba.conf
I, [2025-02-23T11:41:32.534935 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/15/main/pg_hba.conf
I, [2025-02-23T11:41:32.535476 #1] INFO -- : > if [ -f /root/install_postgres ]; then
/root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
initdb: warning: enabling "trust" authentication for local connections
initdb: hint: You can change this by editing pg_hba.conf or using the option -A, or --auth-local and --auth-host, the next time you run initdb.
W: https://dl.yarnpkg.com/debian/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
debconf: delaying package configuration, since apt-utils is not installed
I, [2025-02-23T11:42:52.303584 #1] INFO -- : Generating locales (this might take a while)...
en_US.UTF-8... done
Generation complete.
Upgrading PostgreSQL from version 13 to 15
The files belonging to this database system will be owned by user "postgres".
This user must also own the server process.
The database cluster will be initialized with locale "en_US.UTF-8".
The default database encoding has accordingly been set to "UTF8".
The default text search configuration will be set to "english".
Data page checksums are disabled.
fixing permissions on existing directory /shared/postgres_data_new ... ok
creating subdirectories ... ok
selecting dynamic shared memory implementation ... posix
selecting default max_connections ... 100
selecting default shared_buffers ... 128MB
selecting default time zone ... Etc/UTC
creating configuration files ... ok
running bootstrap script ... ok
performing post-bootstrap initialization ... ok
syncing data to disk ... ok
Success. You can now start the database server using:
/usr/lib/postgresql/15/bin/pg_ctl -D /shared/postgres_data_new -l logfile start
Get:1 http://deb.debian.org/debian bookworm-backports InRelease [59.0 kB]
Get:2 http://deb.debian.org/debian bookworm InRelease [151 kB]
Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:4 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Get:5 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
Get:6 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
Get:7 http://deb.debian.org/debian bookworm-backports/main amd64 Packages [283 kB]
Get:8 http://deb.debian.org/debian bookworm/main amd64 Packages [8,792 kB]
Get:9 http://deb.debian.org/debian bookworm-updates/main amd64 Packages [13.5 kB]
Get:10 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages [246 kB]
Get:11 https://dl.yarnpkg.com/debian stable/main amd64 Packages [10.9 kB]
Get:12 https://dl.yarnpkg.com/debian stable/main all Packages [10.9 kB]
Get:13 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg InRelease [129 kB]
Get:14 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [5,636 B]
Get:15 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 Packages [360 kB]
Fetched 10.2 MB in 2s (6,490 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
libllvm19 postgresql-client-13
Suggested packages:
postgresql-doc-13
The following NEW packages will be installed:
libllvm19 postgresql-13 postgresql-13-pgvector postgresql-client-13
0 upgraded, 4 newly installed, 0 to remove and 12 not upgraded.
Need to get 41.6 MB of archives.
After this operation, 184 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main amd64 libllvm19 amd64 1:19.1.4-1~deb12u1 [25.9 MB]
Get:2 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 postgresql-client-13 amd64 13.20-1.pgdg120+1 [1,538 kB]
Get:3 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 postgresql-13 amd64 13.20-1.pgdg120+1 [13.9 MB]
Get:4 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 postgresql-13-pgvector amd64 0.8.0-1.pgdg120+1 [297 kB]
Fetched 41.6 MB in 2s (18.8 MB/s)
Selecting previously unselected package libllvm19:amd64.
(Reading database ... 33363 files and directories currently installed.)
Preparing to unpack .../libllvm19_1%3a19.1.4-1~deb12u1_amd64.deb ...
Unpacking libllvm19:amd64 (1:19.1.4-1~deb12u1) ...
Selecting previously unselected package postgresql-client-13.
Preparing to unpack .../postgresql-client-13_13.20-1.pgdg120+1_amd64.deb ...
Unpacking postgresql-client-13 (13.20-1.pgdg120+1) ...
Selecting previously unselected package postgresql-13.
Preparing to unpack .../postgresql-13_13.20-1.pgdg120+1_amd64.deb ...
Unpacking postgresql-13 (13.20-1.pgdg120+1) ...
Selecting previously unselected package postgresql-13-pgvector.
Preparing to unpack .../postgresql-13-pgvector_0.8.0-1.pgdg120+1_amd64.deb ...
Unpacking postgresql-13-pgvector (0.8.0-1.pgdg120+1) ...
Setting up libllvm19:amd64 (1:19.1.4-1~deb12u1) ...
Setting up postgresql-client-13 (13.20-1.pgdg120+1) ...
Setting up postgresql-13 (13.20-1.pgdg120+1) ...
Creating new PostgreSQL cluster 13/main ...
/usr/lib/postgresql/13/bin/initdb -D /var/lib/postgresql/13/main --auth-local peer --auth-host md5
The database cluster will be initialized with locale "C.UTF-8".
fixing permissions on existing directory /var/lib/postgresql/13/main ... ok
pg_ctlcluster 13 main start
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Setting up postgresql-13-pgvector (0.8.0-1.pgdg120+1) ...
Processing triggers for libc-bin (2.36-9+deb12u9) ...
Processing triggers for postgresql-common (267.pgdg120+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
Stopping PostgreSQL 13 database server: main.
Stopping PostgreSQL 15 database server: main.
Performing Consistency Checks
Checking cluster versions ok
Checking database user is the install user ok
Checking database connection settings ok
Checking for prepared transactions ok
Checking for system-defined composite types in user tables ok
Checking for reg* data types in user tables ok
Checking for contrib/isn with bigint-passing mismatch ok
Checking for user-defined encoding conversions ok
Checking for user-defined postfix operators ok
Checking for incompatible polymorphic functions ok
Creating dump of global objects ok
Creating dump of database schemas ok
Checking for presence of required libraries ok
Checking for new cluster tablespace directories ok
If pg_upgrade fails after this point, you must re-initdb the
new cluster before continuing.
Performing Upgrade
Analyzing all rows in the new cluster ok
Freezing all rows in the new cluster ok
Deleting files from new pg_xact ok
Copying old pg_xact to new server ok
Setting oldest XID for new cluster ok
Setting next transaction ID and epoch for new cluster ok
Deleting files from new pg_multixact/offsets ok
Copying old pg_multixact/offsets to new server ok
Deleting files from new pg_multixact/members ok
Copying old pg_multixact/members to new server ok
Setting next multixact ID and offset for new cluster ok
Resetting WAL archives ok
Setting frozenxid and minmxid counters in new cluster ok
Restoring global objects in the new cluster ok
Restoring database schemas in the new cluster ok
Copying user relation files ok
Setting next OID for new cluster ok
Sync data directory to disk ok
Creating script to delete old cluster ok
Checking for extension updates notice
Your installation contains extensions that should be updated
with the ALTER EXTENSION command. The file
update_extensions.sql
when executed by psql by the database superuser will update
these extensions.
Upgrade Complete
