After running server updates on the my Digital Ocean server I’ve been experiencing lots of these errors. Any suggestions?
We are going to need a lot more info, what is an example error in http://yourforum.com/logs
Click on “share” on one of the errors, paste the text here
What plugins do you have installed?
Additional plugins are:
I deactivated the “Abbreviation” plugin a few days ago because I think it caused a few problems.
Can you remove abbreviation plugin completely and rebuild your container?
[quote=“sam, post:8, topic:39690, full:true”]
[/quote] Yes, I can do that.
So, even though a plugin has been deactivated it can still have an impact?
Yes, some plugins do not implement the disable bits right.
Thanks. That worked.
