קבוצות פרטיות ב-Discourse
I am trying to create a private group but it does not show up in the list of groups. How can a solve this?
That’s the expected behavior. If a Group is private, it wouldn’t show up in the list of groups. What you might be trying to achieve is a limited access group i.e make group visible to everyone but use the Access submenu to limit their ability to Join the group.
I tried that but it does not show up on the closed group section either.
Can you access the group that you’ve created by your-domain/g/group-name?
To check if it was successfully created.
No, I cannot see the group when I search for it with the name.
Was there an error when you tried to create it?
Maybe try again to create it?
Hi guys!
I tried creating the group again and it worked, thanks to all of you for your help :slight_smile:
