Is that in fact a bug though?
I think itâs an improvement to the dropdown, not really a bug. So you were right about re-categorizing as a feature.
Lesson: I am always right. I knew it!
Except when you are wrong!
I can see how this is open to interpretation and am fine with the categorization.
But I will have to turn this off until the feature is implemented, or limit how we use tags in my community.
Regardless, there is zero concept of âprivate tagâ thatâs something you made up in your head
If anything this is a feature request for an explicit boolean toggle that says âthis tag can only be used and seen by staffâ or what have you.
That said, it is sensible to enhance the drop-down so it does not show you empty tags in the category, e.g. tags that have zero topics represented in that category.
Yup - makes sense. But is there anywhere else in discourse where you can see tags used in topics posted in categories you donât have access to?
I look forward to this:
Would you consider this? It would solve a slew of problems for us.
I thought @sam already built that feature? Perhaps he can clarify since I know there are staff-only tags here on Meta. But they are visible to everyone. Not sure if that meets your needs or not.
Itâs close but them being visible to staff only is what we really want.
Can you open a different topic explaining the use case with real world examples please?
Will do @codinghorror
I just read through this topic again and realized that, actually, what you wrote here is precisely what I am requesting. If this were implemented, my OP complaint above would be resolved.
And to satisfy all use cases to me it would seem sensible to add a site setting to âshow empty tags to usersâ, ensuring /tags and the tags drop-down work in the same way, both ways. So with it enabled /tags would work as the drop-down currently does, and with it disabled the drop-down would work as /tags currently does. (I think Iâve got that the right way round)
You got it!
Can you make a new topic about it if this isnât about the private tags issue? Save me re-reading this ancient topicâŚ
