Enable tagging only in some categories
The discussion is about enabling tagging only in specific categories. tomwrench suggests adding an option to “enable tags in category” in the category modal, allowing specific tags to be used only in certain categories. neil notes that this is doable but will have to focus on other tag features first.
tomwrench and Terrapop agree that the tag filter should only be shown when a user navigates to a category with tags enabled. Terrapop suggests adding a checkbox to limit a tag group to only assigned categories.
Canapin shares a use case where tags are only needed in specific categories and provides a workaround using CSS and JavaScript to hide the tag selector in certain categories. Terrapop agrees that this should be a core feature.
The discussion also highlights issues with the current tag system, such as showing the tag selection box when there are no tags available for a category. Terrapop notes that the code should consider user context and only show tags available to the user.
Canapin updates the JavaScript code to fix issues after a recent Discourse update. Angelo jokes about the six-year wait for a resolution. sam suggests that tag group functionality can provide a close experience to what is being requested, but notes that a checkbox in the category settings would require careful consideration.
This is looking good @neil. One thing that would be good relating to this would be the simple option to ‘enable tags in category’ option in the category modal.
In my use case I only want tags (and specific tags at that) to be able to be used in specific categories. E.g. in those categories where I don’t want tags enabled I wouldn’t want the tag input field to be shown to users. Is this doable?
4 лайка
It’s probably doable, but I have to focus on completing some other tag features first. Will have to come back around to this one later.
9 лайков
I would love to only enable tags in certain categories as well - bookmarking this thread to keep an eye on the discussion moving forward
I think this is currently possible in the way that you can define tag-groups and you can configure category setting in order to use that tag-group.
do you mean something else?
3 лайка
Another feature that would make sense related to this:
If tag filter is enabled, yet only certain categories have tags availble using the ‘Tags that can only be used in this category’ in category settings, I believe the homepage (both the main category, latest and top) pages should have the tag filter disabled by default.
I.e. only when digging down into the categories/sub-categories with tags allowed should the tag filter be shown (showing the respective tags available).
Otherwise from the homepage (whether that be categories or latest), you’ll get a whole bunch of tags in the filter, often without context as they only have context when filtered inside their respective categories.
Does this make sense?
1 лайк
Keen to test this out. Am I able to grab some code somewhere for this? Cheers.
100% согласен. В нашем примере у нас есть раздел документальных фильмов с выделенной группой тегов. Я хочу, чтобы здесь отображался выпадающий список тегов, содержащий только эти выделенные теги. Это работает.
Однако я не хочу, чтобы те же теги были доступны в выпадающем списке на верхнем уровне для «Последние» и «Лучшее» по всем категориям. На мой взгляд, это лишает смысла выделение групп тегов для определенных категорий и создает путаницу на верхнем уровне.
В выпадающем списке тегов на верхнем уровне должны отображаться только глобальные теги, которые не назначены ни одной группе тегов, привязанной к категории.
В настройках группы тегов должно быть что-то вроде:
[ ] Ограничить эту группу тегов только назначенными категориями, не отображать в выпадающих списках верхнего уровня
1 лайк
Это то, что я тоже хотел бы видеть.
На моем первом (импортированном) форуме мне потребовалась категория объявлений.
Поскольку в Discourse нет понятия «папки», содержащей категории, как в других движках вроде vBulletin или phpBB, у меня было по сути три варианта:
  1. Одна категория объявлений для объявлений «купить» и «продать», где пользователи сами добавляли бы префиксы [КУПИТЬ] или [ПРОДАТЬ] в заголовки тем (так что 2000…)
  2. Одна категория объявлений, где пользователи могли бы использовать теги «купить» или «продать». Это самый удобный вариант, но у нас не было необходимости в тегах для других категорий, и пользователи видели бы поле тегов в редакторе для любой категории, что могло бы запутать.
  3. Наличие двух категорий объявлений на верхнем уровне: «купить» и «продать». Это тот выбор, который мы сделали;
Я импортирую другой, более крупный форум, и у меня возникает точно такая же «проблема», за исключением того, что мне нужны теги для двух категорий вместо одной: категории объявлений и категории «другие языки», содержащей только посты на иностранных языках, для которых будет использоваться специфический тег языка, на котором они написаны, например «иврит», «датский» и т. д.
И снова у нас нет необходимости в тегах для других категорий.
Мне нужен был бы селектор тегов в навигационной панели списка тем для обеих этих категорий, но не для других категорий.
Я мог бы легко скрыть его при необходимости с помощью небольшого количества CSS, но главная проблема — это поле ввода тегов в редакторе, которое нельзя отображать или скрывать по желанию…
Думаю, на данном этапе лучшим решением будет переопределить метод tagValidation редактора.
Каждый раз при выборе категории в редакторе он будет скрывать или отображать поле ввода тегов в зависимости от выбранной категории.
Когда поле тегов скрыто, оно будет выглядеть так, с пустым пространством:
Кроме того, это может потенциально нарушить макет, если мы используем плагины или компоненты тем с пользовательскими полями редактора, например плагин location.
Я пробую метод, который придумал как обходное решение.
Скрытие селектора тегов в списке тем с помощью CSS:
(вам нужно указать каждый категорию, поддерживающую теги, в вашем CSS-селекторе)
body:not(.category-other-languages):not(.category-trading-post) {
    .category-breadcrumb .tag-drop {
        display: none;
Показ и скрытие селектора тегов в композере с помощью JS:
<script type="text/discourse-plugin" version="0.8.23">
    // показывать выбор тегов в композере только при необходимости
    const discourseComputed = require("discourse-common/utils/decorators").default;
    const EmberObject = require("@ember/object").default;
    function toggleTagChooser(display = "hide") {
        if (display == "show") {
            document.getElementsByClassName("mini-tag-chooser")[0].style.display = "block";
            document.getElementsByClassName("reply-area")[0].classList.add("with-tags");
            return;
        // Проверка существования выборщика тегов
        let tagChoser = document.getElementsByClassName("mini-tag-chooser");
        if(tagChoser.length > 0) {
            tagChoser[0].style.display = "none";
            document.getElementsByClassName("reply-area")[0].classList.remove("with-tags");
        return;
    api.modifyClass('controller:composer', {
        @discourseComputed("model.category", "model.tags", "lastValidatedAt")
        tagValidation(category, tags, lastValidatedAt) {
            // пользовательский код для переключения выборщика тегов
            toggleTagChooser("hide");
            if(category != null) {
                if (
                    category.allow_global_tags == true ||
                    category.allowed_tag_groups.length > 0 ||
                    category.allowed_tags.length > 0
                    toggleTagChooser("show");
            // конец пользовательского кода
            const tagsArray = tags || [];
            if (this.site.can_tag_topics && !this.currentUser.staff && category) {
                // category.minimumRequiredTags учитывает как minimum_required_tags, так и required_tag_groups
                if (category.minimumRequiredTags > tagsArray.length) {
                    return EmberObject.create({
                        failed: true,
                        reason: I18n.t("composer.error.tags_missing", {
                            count: category.minimumRequiredTags,
                        lastShownAt: lastValidatedAt,
</script>
1 лайк
Именно то, что я искал. Отлично.
В текущем исходном коде ядра особенно неправильно показывать окно выбора тегов, когда для пользователя нет доступных тегов для выбора в категории. Последнее решение устраняет эту проблему с пользовательским опытом. В ядре это должно быть реализовано именно так, @team
Кроме того, для выпадающего списка выбора тегов должны быть предусмотрены два стандартных текста:
«необязательные теги»
и один для случая, когда теги обязательны (и доступны пользователю) для категории:
«выберите не менее X тегов»
1 лайк
Создав группу тегов, вы можете сделать обязательным использование одного из набора тегов («покупка» или «продажа») во всех сообщениях в категории.
1 лайк
Тем не менее, в редакторе для категории с обязательной группой тегов по-прежнему отображается поле выбора тегов с надписью «опциональные теги», а также оно появляется в категориях, где для пользователя недоступны теги в другой категории. С точки зрения UX это довольно запутанно. Пользователь должен увидеть всплывающее окно с ошибкой, чтобы понять, что требуется.
1 лайк
Я понимаю, я просто хочу каким-то образом скрыть функцию тегов для категорий, где теги недоступны, как объясняет @Terrapop.
Когда теги отключены в настройках сайта, селектор категорий находится на той же строке, что и заголовок темы:
С моим обходным решением немного теряется место, так как селектор категорий всегда располагается под заголовком темы:
С одной стороны, изменение позиции селектора категорий при выборе категории в зависимости от того, требуются ли для неё теги, может быть ошибкой в UX. С другой стороны, мы редко используем селектор категорий более одного раза.
1 лайк
Меня беспокоит не столько пустая трата места, сколько ещё одна «проблема» в вашем в остальном отличном JS-коде. Возможно, вы сможете это проверить?
У нас есть группы тегов, доступные только для сотрудников (например, скрытые теги и системные теги), а также обязательные группы тегов для пользователей в зависимости от категории. Обе эти группы связаны через опцию «Ограничить эти группы тегов данной категорией».
В данном случае код проверяет только то, разрешены ли теги в категории или есть ли элементы в массиве tag_groups.length > 0 или allowed_tags > 0. К сожалению, это условие всегда выполняется, так как в ограниченных группах тегов присутствуют и те группы, которые предназначены только для сотрудников.
Можно ли изменить код так, чтобы он учитывал контекст пользователя и проверял, доступны ли действительно теги для конкретного пользователя?
                if (
                    toggleTagChooser("visible");
Возможно, для не-сотрудников следует подсчитывать только публичные элементы в массиве category.allowed_tag_groups.length (или в массиве доступны только имена, но не их статусы):
public_category.allowed_tag_groups = [public_tag_group.name, staff_only_tag_group.name]
private_category.allowed_tag_groups = [private_tag_group.name, staff_only_tag_group.name]
Хорошо, обновление:
В нашем случае мы будем проверять имена в массиве allowed_tag_groups и исключать их из массива, если currentUser не является сотрудником. Но это грязный обходной путь, так как я не знаю, как добавить контекст пользователя сюда (или возможно ли это вообще с учётом текущего базового кода; думаю, что нет).
             var non_staff_tag_groups = category.allowed_tag_groups.filter(filterHidden);
                function filterHidden(value) {
                  if(value.toLowerCase().indexOf("hidden") === -1 && value.toLowerCase().indexOf("system") === -1) return value;
                if (
                    (category.allowed_tag_groups.length > 0 && this.currentUser.staff) ||
                    (non_staff_tag_groups.length > 0 && !this.currentUser.staff) ||
Но это всё равно грязный хак: весь выпадающий список тегов в композере должен быть более контекстным на уровне ядра и учитывать все вышеперечисленные случаи.
2 лайка
Извините, похоже, я не увидел ваше сообщение в 2020 году!
В любом случае, мой код перестал работать после недавнего обновления Discourse. Вот исправленная версия (хотя CSS при этом не меняется):
Укажите классы категорий, для которых нужно скрыть селектор тегов:
        display: none;
Скрипт, который будет динамически включать или выключать селектор тегов:
            return;
        // Проверка наличия выбора тегов
        return;
            // пользовательский код для переключения выбора тегов
                if (
                        failed: true,
</script>
Кстати об этом… прошло уже 6 лет, чувак :sweat_smile:
Думаю, функциональность групп тегов сегодня обеспечивает очень близкий опыт.
Вы привязываете группу тегов к набору категорий, а затем запрещаете создание новых тегов.
Не уверен насчёт pr-welcome здесь; если его убрать, желаемое изменение должно быть чётко описано. Полагаю, речь идёт о добавлении флажка в настройки категории, но даже это требует тщательного обдумывания: должен ли он быть установлен по умолчанию, или такое дополнительное решение просто запутает многих пользователей?
