Problem after installing plugin
Ahmed26 reported that after installing three plugins (Gamification, Who’s Online, and Reactions) and running ./launcher rebuild app, their site was inaccessible for 15–20 minutes before recovering on its own. They confirmed transactions were correct but noted errors in a screenshot posted. Lilly and pfaffman asked for plugin details and error logs, noting the site was accessible to them. pfaffman suspected insufficient RAM (Ahmed26 has 2GB RAM, 2x CPU) and clarified that rebuild app typically takes time, but start should not. Ahmed26 confirmed the delay occurred after rebuild completed — a first-time issue despite 50+ prior plugin installs. pfaffman suggested it might be a fluke, advised testing restart app, and cautioned that rebuilding again would cause 15+ minutes of downtime. merefield recommended switching from PuTTY to Windows Terminal.
After installing the plugin, I cannot access my site. My transactions are correct. There are errors in the picture. What is the problem?
tarihforum.com
Can you please post which plugin you just installed and any other details, and also paste the error txt in a post, it is too difficult to read in the screenshot. Please also make sure you are on a latest Discourse version.
Can you access your site in safe mode? I just visited it myself and it is not down.
It’s working for me.
What plugin did you install?
Were you getting a 502 error that went away 2 minutes after you posted this?
I installed 3 plugins
Gamification ,who’s online , reaction
./launcher rebuild app After entering the code, when the installation was completed, my site did not open for 15 20 minutes.
The site opened later on its own.
You probably need more RAM. How much RAM do you have? This isn’t a RPi, is it ?
It’s expected that a ./launcher rebuild app would take 20 minutes, but not a ./launcher start would take 20 minutes. That usually takes about 2.
PuTTY ew.
Do yourself a favour and install Windows Terminal.
2 GB ram 2xcpu
And it took 20 minutes after the ./launcher rebuild app completed?
yes this is the first time
I couldn’t reach the site for 20 minutes
I’ve installed plugins 50 times before and nothing like this has ever happened.
It could be a fluke, then.
You can see if ./launcher restart app takes a long time.
You could rebuild again (which will have 15+ minutes of downtime).
