Problem migrating polls: `integer out of range` (1000000000000)
Continuing the discussion from Rubygems: Too Many Requests problem returns!:
Well, perhaps the 429 errors are spurious. Further down in the logs I get this:
I, [2018-12-04T20:54:58.204054 #16]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::NumericValueOutOfRange: ERROR:  integer out of range
: INSERT INTO polls (
  post_id,
  name,
  type,
  status,
  visibility,
  close_at,
  min,
  max,
  step,
  anonymous_voters,
  created_at,
  updated_at
) VALUES (
  2228144,
  'poll',
  0,
  0,
  1,
  NULL,
  1,
  1000000000000,
  NULL,
  NULL,
  '2017-12-29 23:26:56 UTC',
) RETURNING id
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/patches/db/pg.rb:92:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql/database_statements.rb:75:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql/database_statements.rb:74:in `block in execute'
Perhaps this could be helpful:
```text
PostCustomField.where(post_id: 2228144)
=> [#<PostCustomField:0x000055f1950311a0
  post_id: 2228144,
  value:
   "{\"poll\":{\"options\":[{\"id\":\"d15fe6bb7788613d049786a7436c44a1\",\"html\":\"win\",\"votes\":8,\"voter_ids\":[216,38,284,3740,373,2795,6351,564]},{\"id\":\"464e1fad0d18eefccca23fe69cba7d2c\",\"html\":\"lose\",\"votes\":2,\"voter_ids\":[408,3582]},{\"id\":\"c58d6a1219a0a366268341e1d315d301\",\"html\":\"equal\",\"votes\":0,\"voter_ids\":[]}],\"voters\":10,\"status\":\"open\",\"min\":\"1\",\"max\":\"1000000000000\",\"public\":\"true\",\"name\":\"poll\"}}",
  created_at: Fri, 29 Dec 2017 23:26:56 UTC +00:00,
  updated_at: Fri, 29 Dec 2017 23:26:56 UTC +00:00>,
 #<PostCustomField:0x000055f195030700
  post_id: 2228144,
  value:
   "{\"408\":{\"poll\":[\"464e1fad0d18eefccca23fe69cba7d2c\"]},\"216\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]},\"3582\":{\"poll\":[\"464e1fad0d18eefccca23fe69cba7d2c\"]},\"38\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]},\"284\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]},\"3740\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]},\"373\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]},\"2795\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]},\"6351\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]},\"564\":{\"poll\":[\"d15fe6bb7788613d049786a7436c44a1\"]}}",
  updated_at: Fri, 29 Dec 2017 23:26:56 UTC +00:00>]
[2] pry(main)>
Oh, Yeah. Someone thought that 1000000000000 would be a good maximum number.
So I guess I either need to submit a PR that catches a too-big max or contrive to fix it in that JSON blob in the current database.
3 curtidas
Hey, if I do a global replace of 10000000000 to 10000 (and there aren’t any such that there will still be too-big numbers) will the polls get rebaked?
Edit: I looks like there was just one. I edited it in the UI and am attempting to bootstrap again now. . . .
Edit: And, fixing the single stupid max lets migrations run.
I’d call it a :bug:, but definitely an edge case!
1 curtida
Thanks :+1:
I fixed the migration so we properly migrate all the integers (min, max, step & anonymous_voters)
4 curtidas
