evgeny-k
(Evgeny)
1
details tag doesn’t work if it is inside list:
Summary
the same for numbered lists
Slowhand
(Slowhand)
I’ve had that problem and solved it by putting a blank line after the bulleted item. There apparently has to be some space before the ‘details’ tag.
SidV
3
Yes, but, if you do that, the “details” will be out of the “list”
cpradio
(cpradio)
4
* Bulleted list item
[details=Summary]
<img src="//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/meta/original/3X/a/0/a000391420c8a13b1e619a17fe97513808b98532.png" width="191" height="102">
[/details]
The above seems to work
Bulleted list item
Summary
