Problemen met libv8-node bij installatie
Hello Discourse Team,
I currently try to install my developer environment on my Raspberry Pi 4B
It says when I am trying to start the rails server
Ive already tried installing it via gem and bundle it says the installation succeed but when I am trying to start the rails server it failed again with the same Error.
Which model of Raspberry Pi it is? (E.g. 2/3/4)
Raspberry Pi 4B with 8 GB Ram
What OS are you running on your Raspberry Pi4? Is it the 64-bit version?
Raspbian/Debian 64bit Version
I have fixed the first error with libv8-node.
It was because I was forcing the config to use ruby.
The Problem now is that I need glibc required by nokogiri to use discourse dev
Error:
rake aborted!
LoadError: /lib/aarch64-linux-gnu/libm.so.6: version GLIBC_2.29' not found (required by /home/pi/.rbenv/versions/2.7.6/lib/ruby/gems/2.7.0/gems/nokogiri-1.13.6-aarch64-linux/lib/nokogiri/2.7/nokogiri.so) - /home/pi/.rbenv/versions/2.7.6/lib/ruby/gems/2.7.0/gems/nokogiri-1.13.6-aarch64-linux/lib/nokogiri/2.7/nokogiri.so /home/pi/discourse/config/application.rb:21:in <top (required)>’ /home/pi/discourse/Rakefile:7:in require' /home/pi/discourse/Rakefile:7:in <top (required)>’ /home/pi/.rbenv/versions/2.7.6/bin/bundle:25:in load' /home/pi/.rbenv/versions/2.7.6/bin/bundle:25:in ’ (See full trace by running task with --trace)
How can I install it?
Here are the news:
I tried installing Librarys ending up destroying my raspian.
know I reinstalled to Raspian 22 64bit
And it worked after updating node!!!
