مشكلة مصدر Prometheus مع SecureRandom (متعددة المواقع؟)
Hey, @sam. I just tried to bootstrap a multisite instance and got this error:
I, [2017-10-30T17:12:58.767601 #14]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
NoMethodError: undefined method `bytes' for SecureRandom:Module
/var/www/discourse/plugins/discourse-prometheus/lib/big_pipe.rb:11:in `<class:RobustPipe>'
/var/www/discourse/plugins/discourse-prometheus/lib/big_pipe.rb:9:in `<class:BigPipe>'
/var/www/discourse/plugins/discourse-prometheus/lib/big_pipe.rb:7:in `<top (required)>'
/var/www/discourse/plugins/discourse-prometheus/plugin.rb:8:in `require_relative'
/var/www/discourse/plugins/discourse-prometheus/plugin.rb:8:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:412:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:412:in `activate!'
/var/www/discourse/lib/discourse.rb:146:in `block in activate_plugins!'
/var/www/discourse/lib/discourse.rb:143:in `each'
/var/www/discourse/lib/discourse.rb:143:in `activate_plugins!'
/var/www/discourse/config/application.rb:178:in `<class:Application>'
/var/www/discourse/config/application.rb:26:in `<module:Discourse>'
/var/www/discourse/config/application.rb:25:in `<top (required)>'
/var/www/discourse/Rakefile:5:in `require'
/var/www/discourse/Rakefile:5:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.1.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:22:in `load'
/usr/local/bin/bundle:22:in `<main>'
I, [2017-10-30T17:13:10.161589 #14]  INFO -- :
Removing Prometheus plugin solved the problem.
(This should be a new topic in bug and not a reply to Discourse Prometheus, right?)
That’s not a multisite issue, that’s because that instance is not running Ruby 2.4 or higher.
Doh!
git pull
./launcher bootstrap multi
Thanks, @RGJ!
