Pros & Cons topics
Discussion Title: Pros & Cons topics
leog inquired about a feature to facilitate debates around the pros and cons of certain topics, similar to kialo.com. They suggested it could be a plugin or a core feature, providing insights and statistics about gathered opinions.
codinghorror referenced a search result regarding debates and the economist, but leog couldn’t find a direct answer to their question. leog stated that while a plugin could potentially exist, it would require significant effort and isn’t in the Discourse core roadmap.
codinghorror provided additional references, including slant.co, which is built around pros and cons, offering examples of how this concept can be implemented.
Hello! I was wondering if there is any feature to cover what kialo.com provides: a debate around pros & cons of certain topic.
I would think that a feature like that could be shaped as a plugin but as it could modify the workflow of a topic, providing insights and statistics about the gathered opinions etc, maybe it could be a core feature.
Anyway, I wanted to officially ask about it as it would be difficult to move from Discourse by now being that it could perfectly fulfil the same requirements Kialo provides.
Thanks in advance, cheers!
Search for posts by me containing the word “economist”
https://meta.discourse.org/search?q=%40codinghorror%20economist
Thanks for that reference @codinghorror. Couldn’t find an answer to my question though.
I guess that a plugin could potentially exist to gather requirements around providing an easy-to-understand UX covering Pros&Cons feature, but that would be require a huge effort to implement, and is not in the roadmap for Discourse core, right?
In addition to the economist debate pros and cons links I previously provided in the search results, you can look at https://www.slant.co/ for examples of a site built around pros and cons too
like so
https://www.slant.co/topics/1978/viewpoints/1/~gps-navigation-apps-for-android~google-maps
