I think that’ll make it harder. You can delete stuff that’s bad, and if it happens much you can stop allowing anonymous. Do you have trouble weet people misbehaving now? If not, then you probably won’t have trouble giving them this ability. Don’t try to solve problems that you don’t have.
That information is stored in the database and you can use the following data explorer query to retrieve the real user behind a post. Using IP addresses to find the user is not accurate.
-- [params]
-- int :topic_id
-- int :post_number
SELECT u.id AS user_id, p.id AS post_id
FROM users u
LEFT JOIN anonymous_users ua ON ua.master_user_id = u.id
LEFT JOIN posts p ON ua.user_id = p.user_id
WHERE p.topic_id = :topic_id AND p.post_number = :post_number
