Publishing multisite
The discussion revolves around setting up a multisite Discourse installation using Docker. DursunCan asks whether installing Discourse in a discourse2 folder and running ./discourse-setup will successfully install the site, noting that port 80 is already in use by Docker processes. pfaffman clarifies that ./discourse-setup is not suitable for multisite configurations and directs to guides on multisite Docker setups, including using a reverse proxy and running multiple containers with separate app.yml files. The thread emphasizes that discourse-setup is only for simple installations, not multisite deployments.
discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub I read the post on the link and set up 1 site.
git clone https://github.com/discourse/discourse_docker.git /var/discourse2
If I install it to the discourse2 folder and run the command ./discourse-setup, will the site be installed?
Do I have to do anything with the nginx port?
Port 80 appears to already be in use.
This will show you what command is using port 80
COMMAND    PID USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
docker-pr 1241 root    4u  IPv4  26166      0t0  TCP *:http (LISTEN)
docker-pr 1247 root    4u  IPv6  26172      0t0  TCP *:http (LISTEN)
If you are trying to run Discourse simultaneously with another web
server like Apache or nginx, you will need to bind to a different port
See https://meta.discourse.org/t/17247
If you are reconfiguring an already-configured Discourse, use
./launcher stop app
to stop Discourse before you reconfigure it and try again.
No.
See Multisite configuration with Docker and Multisite Configuration with Let’s Encrypt and no reverse proxy.
You can also run multiple containers (copy app.yml, not all of Discourse) with a reverse proxy in front.
You can’t use discourse-setup. It’s just for very simple installations.
