| Summary | Pulse Analytics counts visitors on your forum without cookies or stored IP addresses. | |
| Repository | GitHub - ciphera-net/pulse-discourse: Pulse Analytics theme component for Discourse: privacy-first, cookie-free web analytics. · GitHub | |
| Install Guide | How to install a theme or theme component | |
| New to Discourse Themes? | Beginner’s guide to using Discourse Themes |
Install this theme component
Pulse Analytics adds privacy-first web analytics to a Discourse forum with one theme component. It sets no cookies and never stores IP addresses. The script it adds to your pages is under 3 KB.
Install
- Use the button above, or go to Admin → Customize → Themes → Components → Install → From a git repository and paste
https://github.com/ciphera-net/pulse-discourse. - Add the component to your theme.
- Open its settings and set Domain to the domain your forum is registered under in Pulse. If you leave it empty, the tracker uses the browser’s own hostname, which is right for a forum served on one domain.
- Visit pulse.ciphera.net and watch visitors arrive.
Settings
| Setting | Default | What it does |
| Domain | empty | The domain this forum is registered under in Pulse. If it is empty, the tracker uses the browser’s own hostname. |
| Record clicks, copies and form submits | off | Loads a second, separate script that records interactions. |
| Also track administration pages | off | Tracks administration pages too. They are excluded by default; the README explains how that is enforced on a single-page app. |
| Custom API origin | empty | Sends events through your own proxy origin. |
What it measures
Pulse counts pageviews, referrers, countries, devices, time on page and scroll depth, plus the goals, funnels and campaigns you set up, in one dashboard hosted in Switzerland. It does not count visitors whose browser sends Do Not Track or Global Privacy Control. The component excludes administration pages by default.
Requirements
You need Discourse 3.3 or later and a Pulse Analytics account with a site registered for the same domain. The free plan is enough to start.
Docs: docs.ciphera.net/pulse
