Hmm, interesting… it looks like the quote avatar URL is totally broken there, using localhost:3000 as the host is never the right idea. What version of Discourse are you running?
I don’t think its totally broken. localhost:3000 is where the development server is that I’m running. I’m running d34b4d3 (the latest Master). I might totally have something misconfigured, but I thought it was strange that some links were working and others were not.
Yes. The nginx server is running at 192.168.1.23:80 and it is proxying all connections to a discourse server running on localhost:3000 (via bundle exec rails s). When I connect to 192.168.1.23:80 from another computer, I see the regular discourse site, but the quote avatar images have a img url with a host of localhost:3000, which is not accessible to the other computer.
The link I circled in this screenshot is also using localhost:3000 as the host. That link is supposed to link to the topic this post was split off from.
I am running this discourse instance locally on my machine out of the git repository with bundle exec rails s. I can’t find any file called app.yml. I see references to it relating to docker containers. I am not using a docker container.
How do I find the “site name” when running in development?
All the developer settings are at their defaults according to the settings page:
If this is a development setup then this is a Dev topic, know that we do not support these port overrides on a production site. That is why there are so many warnings on those settings.
If you see the “3000 => 4000” try changing your Admin -> Developer port from 3000 to 4000
You may need to “rebuild HTML” posts that have the broken links in them
I’m not using Vagrant; I’m just running it like I run any other rails app.
It really doesn’t make sense to me that most links / URLs work fine. There really must be some differences in how the links are generated. I think this is at least weird if not a bug.
This setup came up because I was quickly trying to prototype having nginx in front of Discourse. I will try it in a production setup to see if that solves my problem.
