Hi @angus, just a reminder for implementing the hiding comments features.
Again, thank you so much for doing this! Really appreciate it!
@sinister89 Iâve added a visibility toggle for comments. You can set the number of comments to show by default using the site setting qa comments default
Hidden comments for an answer display if:
Example topic: https://discourse.angusmcleod.com.au/t/what-has-cities-but-no-houses-forests-but-no-trees-and-water-but-no-fish/55
Example post with qa comments default set at 2
This is a good change, but if you change useragent on (Android):
Mozilla/5.0 (Android; Mobile; rv:13.0) Gecko/13.0 Firefox/13.0
then the topic will be empty. Perhaps some errors, with the change of the template.
Thankd @angus for the change, really helpful.
I am also seeing the same issue as reported by @Stranik.
I have attached the console log. You can replicate this in a chrome browser by using the device toolbar view of âGalaxy S5â.
Thanks for the report. Please see if this fixed it.
cc @sinister89
Hiding of the comments is working. Thanks.
I unfortunately do not use the plugin, but only part of the code, and perhaps I have only a private case. If there is a new notification, clicking on them, my throws are not at all the answer, and in the middle of the theme. Yet again, maybe itâs just me. I tested it on my computer.
I believe there may be a bug with QA Plugin - but it might be another plugin from your studio @angus.
On a post that is a reply to a previous, nonadjacent post above, pressing the link to the original poster/post opens the summary of that post but throws JS Console errors.
After these errors the page no longer receives updates. Pressing like registers a like with the server but does not refresh the like symbol, new posts no longer automatically appear, etc.
Itâs been driving me crazy for some time trying to centre in on the cause. Finally, Iâve been able to reproduce the issue on my dev site with the QA Plugin enabled and see the issue disappear when the QA Plugin is disabled.
However, on my live site I have disabled the QA Plugin and the error is still there - hence my comment that it might be shared code with one of your other plugins which are still enabled (but Iâm guessing there).
Iâve managed to reproduce this on your sandbox, @angus. Follow these steps.
Open the JavaScript Console
Press the like
on your post âSure thing, go aheadâ (although I believe any like you press will reproduce the problem).
You should see an error in the console
Let me know if you need any more information or if you are not able to reproduce it. I guess it could be something in my environment that is causing the issue.
Cheers, Bletch.
On a site that I have just upgraded, the timeline scroll bar is missing. Disabling the Question Answer Plugin with safe-mode makes it come back.
Also, was there a bug a while back that let someone un-vote more times than theyâd voted? We had a post with -26 votes. I canât replicate it, so I guess itâs been fixed, but knowing that such a bug existed would explain the anomaly.
@bletch Iâve made a few changes. Please update and let me know how it goes.
@pfaffman Is the timeline disabled in all topics or just QnA topics? Itâs meant to be disabled in QnA topics because the timeline doesnât make sense in the context of a non-chronological topic order.
Not that I know of, but itâs possible. I canât repro this in the current version of the plugin. The voting mechanism was changed substantially when this plugin went from using the (now removed) vote_count property in core Discourse to using custom fields (a month or so ago now). It could have been present in the old mechanism.
Are negative votes a live issue in any way?
Will do.
Did you update your sandbox? The issue is still reproducible there
Iâll test and report back.
Doh! Thatâs it. And I think that all categories are QnA.
I canât replicate the negative votes either. Iâve fixed up the one topic by hand and told them that unless it can be replicated it canât be fixed. ![]()
Thanks.
Hi @angus, Iâve tested the latest version of the QA Plugin on our live site and I canât reproduce the problem.
As I mention above, Iâm wondering if the problem is in code shared across plugins because I re-enabled your Elections Plugin (which I had disabled whilst trying to track down the bug) and I was then able to reproduce the problem again.
Both the Elections and the QA Plugin were enabled at that point.
Disabling the Elections plugin, but leaving the QA Plugin enabled meant that I was no longer able to reproduce the problem.
So it looks fixed in the QA Plugin but maybe still present in the Elections Plugin?
Thanks for all your efforts, itâs really appreciated out there in Discourse land!
Cheers, Bletch.
@bletch Youâre right, the same issue is also present in the elections plugin. Nice sleuthing
I can see whatâs causing it, but the solution I used for QnA wonât work for elections. Iâll have to take a closer look on the weekend.
I have alot of category, about 2500 category, How do i setup all of them enable Answer Plugin?
Thank you!
If you want to literally make all categories QA:
./launcher enter app
rails c
Category.all.each do |c|
c.custom_fields['qa_enabled'] = true
c.save_custom_fields(true)
But youâll probably want to exclude some categories (youâll need to update the part that starts 'other names...').
rails c
if ['Staff', 'other names of categories you want to exclude'].exclude? c.name
Thank you so much!
i Done!
My entire website is focused on Q&A, which relies on this plugin.
Recently, Iâve encountered issues where new or updated answers appear at the top, while the questions move to the bottom of the page. For example: https://transit.travel/t/shops-selling-aldraat-kuwait/37435/2
How can I resolve this?
I tried rebaking posts and rebuilding Discourse, but without success.
Sorry youâre having an issue. Iâll take a look tomorrow.
Looking at your site, it seems that topic is the only one with the issue. Are there any others?
As to that topic, I suspect the issue is caused by the fact that itâs a three year old topic and you installed the question answer plugin after the topic was created.
The recent post is a âcommentâ on an answer which is why it appears near the top (it is appearing correctly under the answer it is comment on).
The issue is that the question is appearing at the bottom of the topic for some reason. Iâve made a tweak to the order logic which should fix it. Youâll need to update and then create a new answer or comment in that topic (you can delete it afterwards).
