Quick Profile Links Menu
That I was expecting, but it doesn’t happend. Ok, I’ll start digging if there is some conflict or am I suffering of too little caffein.
Edit. Perhaps I really need more coffee. I misunderstood totally the system. I thought that previous tab will show up, but it was all about that edit-box on profile page. Right?
Appreciate this!
This is a really cool concept, excellent job! :clap:
This is nitpicking; when I visited the settings, I can suggest you to use identifier. This way, it could display the label instead of “item x”./
E.g:
Thanks @Arkshine, I added it. :slightly_smiling_face:
FYI: Some of the recent changes broke this:
Thanks, I merged a fix :slightly_smiling_face:
One shy question. How should we deal with different languages?
Right now this is just an academic issue for me, because I have only finns in Finnish forum, and nowadays practically every device uses locales by given location, but if the team get translation system in working phase, it can change. Perhaps.
Hello :wave: Here is the update to make it possible. DEV: Makes profile menu preference items translatable by VaperinaDEV · Pull Request #4 · VaperinaDEV/quick-profile-links-menu · GitHub
If you leave empty the label field in profile_menu_preference_items setting, the default translation key of the menu will be used :down_arrow: based on the value selected in the page dropdown.
Screenshot 2025-05-10 at 13.37.27
Nice! It works just as expected.
Is it possible to only enable the option in the user profile and not replace the dropdown toggle menu?
Hello :wave: Yes, here is the update: DEV: Adds a setting to enable user profile links dropdown by VaperinaDEV · Pull Request #5 · VaperinaDEV/quick-profile-links-menu · GitHub
It adds a new setting enabled_user_profile_dropdown uncheck it will disable the menu on profile page.
Thanks, works great. Much appreciated.
This theme component causes issues with the first two dropdowns on Preferences - Email
