Hi,
when going through the config, I stumble across the rake command here and there, which I am supposed to run to do certain things. However, if I go into my Discourse folder /var/discourse and enter “rake”, my Ubuntu tells me this command is not installed.
Do I need to install it? Or do I have to get inside the container somehow and run it from there?
Thanks from a total newb ™. ![]()
