Rake uploads:migrate_to_s3 errore
2.4.0.beta9 discourse latest-release +35
> rake uploads:migrate_to_s3
rake aborted!
NoMethodError: metodo `name' non definito per :vapid_public_key:Symbol
/var/www/discourse/plugins/procourse-custom-homepage/lib/dl_custom_homepage/engine.rb:42:in `block in <top (required)>'
/var/www/discourse/lib/discourse_event.rb:14:in `block in trigger'
/var/www/discourse/lib/discourse_event.rb:13:in `trigger'
/var/www/discourse/lib/site_setting_extension.rb:355:in `add_override!'
/var/www/discourse/lib/site_setting_extension.rb:508:in `block in setup_methods'
/var/www/discourse/config/initializers/100-push-notifications.rb:18:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:319:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:319:in `block in load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/dependencies.rb:291:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/engine.rb:667:in `block in load_config_initializer'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/notifications.rb:182:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/engine.rb:666:in `load_config_initializer'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/engine.rb:624:in `block (2 levels) in <class:Engine>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/engine.rb:623:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/engine.rb:623:in `block in <class:Engine>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:50:in `tsort_each_child'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/application.rb:363:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/config/environment.rb:7:in `<top (required)>'
ancora quando eseguo git pull sul codice sorgente e ricompilo l’app fino a (f7a7263164)
Verifica se la migrazione predefinita è già stata eseguita...
2 di 300 upload non sono stati migrati su S3. La migrazione S3 è fallita per il database 'default'.
Ricerca di upload mancanti su: default
0 upload di post sono mancanti.
Nessun post richiede una ricottura
Migrazione degli upload su S3 per 'default'...
Caricamento dei file su S3...
 - Elenco dei file locali => 284 file
 - Elenco dei file S3 => 285 file
 - Sincronizzazione dei file su S3
Aggiornamento degli URL nel database...
Rimozione delle immagini ottimizzate vecchie...
Segnalazione di tutti i post contenenti lightbox per la ricottura...
3 post sono stati segnalati per una ricottura
rake aborted!
/var/www/discourse/lib/tasks/uploads.rake:238:in `migration_successful?'
/var/www/discourse/lib/tasks/uploads.rake:551:in `migrate_to_s3'
/var/www/discourse/lib/tasks/uploads.rake:216:in `block in migrate_to_s3_all_sites'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:73:in `each_connection'
/var/www/discourse/lib/tasks/uploads.rake:214:in `migrate_to_s3_all_sites'
/var/www/discourse/lib/tasks/uploads.rake:210:in `block in <top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => uploads:migrate_to_s3
(Vedi la traccia completa eseguendo il task con --trace)
  1. rake posts:rebake funziona
    ho anche provato DISCOURSE_S3_BUCKET="antivteassets/uploads"
DISCOURSE_S3_BUCKET="antivteassets"
2.
rake uploads:migrate_to_s3 --trace
** Invoke uploads:migrate_to_s3 (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute uploads:migrate_to_s3
Checking if default already migrated...
2 of 301 uploads are not migrated to S3. S3 migration failed for db 'default'.
** Invoke posts:missing_uploads (first_time)
** Execute posts:missing_uploads
Looking for missing uploads on: default
0 post uploads are missing.
No posts require rebaking
Migrating uploads to S3 for 'default'...
Uploading files to S3...
 - Listing local files => 284 files
 - Listing S3 files. => 286 files
 - Syncing files to S3
Updating the URLs in the database...
Removing old optimized images...
Flagging all posts containing lightboxes for rebake...
69 posts were flagged for a rebake
rake aborted!
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:476:in `exec'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/exe/bundle:46:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/exe/bundle:34:in `<top (required)>'
Sembra che questo plugin sia la causa principale dell’errore.
in realtĂ
ls: impossibile accedere a '/var/www/discourse/plugins/procourse-custom-homepage': File o directory non esistente
tutti i file immagine sono giĂ  stati trasferiti su S3
Rimuovi quel plugin e ricompila
Non ho questa opzione, né nella directory ls né nella pagina di personalizzazione delle impostazioni del sito.
Strano. Con un rebuild della vecchia app e un nuovo run di migrate
qui https://bbs.antivte.com/t/topic/194
Controllo se la migrazione predefinita è già stata eseguita...
2 di 301 upload non sono stati migrati su S3. Migrazione S3 fallita per il db 'default'.
0 upload dei post sono mancanti.
54 post richiedono ancora il rebaking e verranno elaborati durante il lavoro regolare
 - Elenco dei file locali => 286 file
 - Elenco dei file S3. => 294 file
Rimozione delle vecchie immagini ottimizzate...
Segnalazione di tutti i post contenenti lightbox per il rebake...
69 post sono stati segnalati per il rebake
rake aborted!
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite/connection_management.rb:73:in `each_connection'
Ho fatto un’installazione fresca di Discourse per testare, con le stesse impostazioni S3. Il comando rebake e migrate sono stati eseguiti con successo, ma quando il caricamento delle immagini è completato, l’URL non è ancora l’URL del CDN + nome del file immagine
https://cp.antivte.com/t/topic/14
Sembra che io stia usando Fortify su Cloudflare per
Nove medici su dieci concordano sul fatto che le intestazioni [Content-Security-Policy](https://developer.mozilla.org/en-US/docs/Web/HTTP/CSP), [HSTS](https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/Strict-Transport-Security) e [CORS](https://developer.mozilla.org/en-US/docs/Web/HTTP/CORS) siano parte di una colazione equilibrata.
e aggiunga semplicemente S3 all’intestazione in questo modo, eccolo fatto:
Access-Control-Allow-Origin: https://bbs.antivte.com
Content-Security-Policy: default-src 'self' *.amazonaws.com google-analytics.com
