Hi,
I have just gone through our 121 categories/sub-categories in an attempt to re-order them. It was challenging to say the least.
I decided to implement a numbering system which would separate the categories by thousands, e.g.
1000 - category one
2000 - category two
with sub-categories numbered in multiples of ten in between, I figured this would allow me to re-order later on without having to re-order everything.
1000 - category one
1010 - category one, sub-category one
1020 - category one, sub-category two
2000 - category two
2010 - category two, sub-category one
I found that as I typed a number the box automatically jumped to its new position, but, because the cursor didn’t have focus, the model window didn’t automatically scroll down. Also, after the key press it assumed I was done, for example, if I was to try and type “300” after “30” the box would move, focus would be lost. In the end I used a text editor to type the numbers and then copy and paste them into each box. It took a while and was a bit of effort but eventually, I had removed all of the issues and everything was organised nicely.
The Re-Organise Categories model offered three buttons;
- Fix Positions
- Apply
- Save
Save was disabled, I applied the changes. Save was still disabled. The only way to actually change anything was to click “Fix Positions”, at this point, all of my carefully hand-crafted numbering reverted to a sequential flow of integers, I had lost all of the “spacing” I had injected.
Thankfully, all of the categories and sub-categories were at least in the order I wanted them in, but it wasn’t overly obviously that I couldn’t just number these however I wished. It also wasn’t overly obviously what the “Fix Positions” button was going to do, the hover text just suggested that I had some duplicate numbers, which I didn’t as I had checked them thoroughly.
The ability to have the numbers entered for positioning I think would be beneficial, especially for forums with large quantities of categories/sub-categories. In our specific case they represent courses and sections of courses, as such they will always be being added to and from time to time need some re-jiggling as we may want to move a course to be more prominent on the forum.
