React Theme Components
A discussion on using React components within React Theme Components is underway. edL is exploring the possibility of integrating a React-based header component into an Ember application, citing a client’s need for a reusable, maintainable header across multiple web properties. However, Falco highlights the potential drawbacks of including both Ember and React libraries, resulting in increased load times.
Instead, Falco suggests a more common approach of compiling the header to HTML and importing it into downstream projects. edL considers this, but notes the complexity of dynamic login/register links that depend on the user’s logged-in state. A potential solution is to implement the core header structure in Ember, while incorporating only the frequently changing content area from the React component.
A bit of an odd question, but has anyone tried creating a theme component using React? I’ve seen a couple of sources that make React work with Ember, but I’m not sure if they could be applied within the context of a theme component.
eg:
https://medium.com/front-end-weekly/using-react-components-in-your-ember-app-8f7805d409b0
https://github.com/alexlafroscia/ember-react-components
Use case:
Client has a fancy brand header written in React which is used across all their web properties. This bar features their hero products, and changes regularly, so it would be nice to be able to move it out to its own repository, and have a single place to update it, rather than having to maintain it in Ember, React etc.
From the link:
It does work, but you should be really careful about including both the Ember and React libraries in your application since that’s quite a lot of JavaScript to ship to your users
You gotta carefully evaluate if increasing the load time of the forum so much is really worth it for you.
The more common route here, is that the header is written in anything, but compiled to HTML and every downstream project just imports the resulting HTML.
Thanks for being the voice of sanity :slight_smile:
Consuming the HTML is a much more reasonable approach. The only rub is that the header has Login/Register links that have to change depending on the user’s logged-in state…
Maybe the trick is to implement the core structure of the header, including the dynamic Login, in Ember, and pull in just the content area that changes often.
