Readability Score (a-la HemingwayApp)
The discussion revolves around improving the readability of posts on Discourse using tools like HemingwayApp. brucellino proposed integrating a readability score feature into Discourse, possibly using a JavaScript library like write-good. However, erlend_sh suggested that such a feature is unlikely to be included in the core, but could be implemented as a plugin. erlend_sh also noted that HemingwayApp supports Markdown export, allowing users to compose long-form content outside of the forum and then export it. Alternatively, elijah recommended using a preferred editor to compose posts, and brucellino found these suggestions satisfactory.
Hidyho discourtesans
Every now and again, I like to post well-written topics. I have an idea or a position I want to express, and I want it to come across clearly, albeit in a way that invites discussions. To do this, I like to use HemingwayApp, which parses the text and highlights issues with style (not grammar or punctuation).
Leaving aside license or portability issues, I’m going to assume that there is some javascript magic that can be done in Discourse to help improve the quality of the prose. I don’t know, something like https://www.npmjs.com/package/write-good ?
I’ve done a quick search on this forum to see if anyone else has proposed similar plugins before, but I came up empty. Perhaps this is not widely needed, or is done in some other way ? Enlighten me, please.
3개의 좋아요
Unlikely to ever be in core but fine as a plugin. Also, HemingwayApp supports Markdown export, so for those rare times when you’re composing long form content for a forum post you can type it up in Hemingway and then export the final thing.
3개의 좋아요
The general fix is to use your preferred editor to compose posts instead of a <TEXTAREA> on a webpage. I use the “It’s All Text” add-on in Firefox to edit things in my preferred editor, xterm -e vim
1개의 좋아요
Thanks @erlend_sh and @elijah
I’m satisfied with these suggestions.
2개의 좋아요
