hi
im reinstalling discourse from previous non docker instalation in lxc container to docker version as suggested in forum …just now the script ran long time and i’ve got to a stop with following errors. internet is saying that docker ran out of memmory …but non docker version was working ok so i didnt check the settings from lxc container if it limits docker so if anyone can suggest how to procced on matter. i cleaned LXC from previous versions and started new install and since i have reverse proxy i manualy entered initial values and started rebuild app as is written on forum…
settings from LXC:
cores = 2
memory = 2048
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1179 exit 137>
Location of failure: /usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
bootstrap failed with exit code 137
