La reconstruction échoue sur db:migrate "relation "form_templates" existe déjà"
La reconstruction de Discourse échoue. Voici le journal.
Quelle est la meilleure façon de résoudre ce problème ? Nous avons Postgres hébergé sur RDS et exécutons Discourse avec la méthode officielle du conteneur Docker.
I, [2023-10-25T14:47:59.607563 #1]  INFO -- : cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate'
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::DuplicateTable: ERROR:  relation "form_templates" already exists
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.1.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.1.1/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/dependencies/interlock.rb:41:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:47:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract_adapter.rb:752:in `block in log'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract_adapter.rb:743:in `log'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:46:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/schema_statements.rb:326:in `create_table'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:932:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:900:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:900:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:921:in `method_missing'
/var/www/discourse/db/migrate/20230202173641_create_form_templates.rb:5:in `change'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:870:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:854:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:853:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/connection_pool.rb:215:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:852:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1046:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1360:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/connection_adapters/abstract/database_statements.rb:316:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/transactions.rb:209:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1411:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1359:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1333:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1432:in `block in with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1447:in `with_advisory_lock_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1428:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1282:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1117:in `up'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/migration.rb:1092:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.7/lib/active_record/tasks/database_tasks.rb:262:in `migrate'
/var/www/discourse/lib/tasks/db.rake:250:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:225:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
Cela pourrait être un bug. J’ai modifié le sujet pour fournir un peu plus d’informations.
Quels plugins avez-vous installés ?
Comment trouver des plugins ?
quelque chose comme
cd /var/discourse
grep clone containers/*
J’ai essayé de trouver le répertoire des plugins et voici ceux qui sont répertoriés.
chat	   discourse-details	  discourse-local-dates    discourse-presence  poll
checklist  discourse-lazy-videos  discourse-narrative-bot  docker_manager      styleguide
Nous n’avons rien installé à part les thèmes.
N’avez-vous pas un fichier app.yml quelque part, c’est ce qui est lu lorsque vous effectuez une reconstruction ?
Mais il semble que mon idée n’expliquera rien.
J’ai trouvé app.yml. Il n’y a pas de plugins supplémentaires listés là-bas. Comme je l’ai dit, je suis certain de ne rien avoir installé à part des thèmes.
Voici les étapes que nous avons suivies et qui ont conduit à ce problème.
  • Nous avons essayé de déplacer tous les actifs vers S3 en utilisant rake uploads:migrate_to_s3
  • La commande ci-dessus a échoué, indiquant que 155 des 161 actifs n’ont pas été déplacés.
  • Nous avons essayé de restaurer la version précédente en utilisant “Rollback” dans le panneau de sauvegarde.
  • Le site entier s’est écrasé. Rien ne fonctionne.
  • Lorsque nous avons essayé de restaurer en ligne de commande, il est indiqué que nous essayons de restaurer alors qu’il y a des migrations en attente.
  • Pour exécuter les migrations, nous avons essayé de reconstruire, mais cela a conduit à cette erreur.
J’espère que cela vous donne une idée. D’ailleurs, notre déploiement entier est actuellement cassé. Quelle est la meilleure façon de s’en sortir ? Nous avons la sauvegarde la plus récente prise sur S3 avant que nous commencions tout cela.
Le panneau de sauvegarde RDS ? C’est probablement là que vous vous êtes trompé.
Si la restauration de la sauvegarde la plus récente vous convient, je pense que je créerais une nouvelle base de données, mettrais à jour app.yml avec le nouveau nom de la base de données, m’assurerais que les paramètres S3 pour la sauvegarde sont dans le fichier yml, reconstruirais, restaurerais.
Si vous voulez jeter de l’argent sur le problème, vous pouvez me contacter directement.
Pas le panneau RDS, mais le panneau discourse.
Nous allons essayer pendant un certain temps, mais si cela ne fonctionne pas, nous vous contacterons dans quelque temps.
Nouvelle base de données + nouvelle machine et restauration sur celle-ci a bien fonctionné. Merci pour votre réponse rapide.
