Syntax error in my YAML file
Does anyone knows what could cause this issue by rebuilding app?
Last login: Mon Jan  2 03:50:07 2017 from 122.60.253.1
    root@organic:~# cd /var/discourse
    root@organic:/var/discourse# ./launcher rebuild app
    Fetching origin
    Launcher is up-to-date
    Stopping old container
    + /usr/bin/docker stop -t 10 app
    app
    (<unknown>): found character that cannot start any token while scanning for the next token at line 90 column 1 -e LANG=en_US.UTF-8
    YAML syntax error. Please check your containers/*.yml config files.
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone -b beta https://github.com/gdpelican/babble.git
          - git https://github.com/stereobooster/discourse-vk-login.git
          - cp discourse-vk-login/db/migrate/* db/migrate/
          - git clone https://github.com/communiteq/discourse-adsense.git
          - git clone https://github.com/discourse/discourse-slack-official.git
          - git clone https://github.com/tgxworld/discourse-translator.git
          - git clone https://github.com/defaye/discourse-steam-login.git
Something is wrong with your yml file. Note that yml is incredibly sensitive to whitespace. Try copying your file here: http://www.yamllint.com/. If you still can’t determine the issue, please upload your entire app.yml here for us to take a look. Make sure to remove sensitive information like passwords first!
I’ve got the same issue there by checking :slight_smile:
app.yml (4.9 KB)
What you posted as
is really
Also
You didn’t, so now you should change those.
Now it argues to line 87 :slight_smile:
(<unknown>): did not find expected key while parsing a block mapping at line 87 column 7
I have a feeling you are missing an important fact about YAML files.
http://www.yaml.org/faq.html
Why does YAML forbid tabs?
Tabs have been outlawed since they are treated differently by different editors and tools. And since indentation is so critical to proper interpretation of YAML, this issue is just too tricky to even attempt.
I don’t know what text editor you are using to edit the file, but I suspect you are using tab to create what visually looks like the correct number of spaces to you, but is not the correct number of spaces.
That is, when you edit, use the space bar and not tab.
I’m using the nano editor thru the terminal to make some changes. However for attaching file here I’ve connected to my Droplet by using Cyberduck and copied the body of the YAML file by using a usual text editor on Mac :slight_smile:
Does nano editor and text editor convert the tab gaps to the space gaps? I’ve just saved that file on the text editor and upload to the containers folder, but didn’t help :slight_smile:
Also, I’m wondering, why the YAML checker didn’t show tab spaces for you, when you checked the app.yml file, if there it could happen? :slight_smile:
Fixed by editing app.yml file via http://www.yamllint.com/
  • Cleared my app.yml by connecting thru Cyberduck (made it blank)
  • Copied and editied the information below
  • The already checked information on http://www.yamllint.com/ copied to my app.yml file with blank field
  • Saved and rebuild the build with plugins
  • Profit :slight_smile:
Thanks for everyone :slight_smile:
    ## this is the all-in-one, standalone Discourse Docker container template
    ## After making changes to this file, you MUST rebuild
    ## BE *VERY* CAREFUL WHEN EDITING!
    ## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
    ## visit http://www.yamllint.com/ to validate this file as needed
    templates:
      #- "templates/web.ssl.template.yml"
      #- "templates/web.letsencrypt.ssl.template.yml"
    ## which TCP/IP ports should this container expose?
    ## If you want Discourse to share a port with another webserver like Apache or nginx,
    ## see https://meta.discourse.org/t/17247 for details
    expose:
      - "80:80"   # http
      - "443:443" # https
    params:
      db_shared_buffers: "128MB"
      #db_work_mem: "40MB"
      #version: tests-passed
    env:
      LANG: en_US.UTF-8  ###This is the "offending" line###
      UNICORN_WORKERS: 2
      DISCOURSE_HOSTNAME: <hostName>
      ## Uncomment if you want the container to be started with the same
      ## hostname (-h option) as specified above (default "$hostname-$config")
      #DOCKER_USE_HOSTNAME: true
      DISCOURSE_DEVELOPER_EMAILS: <email list>
      ## TODO: The SMTP mail server used to validate new accounts and send notifications
      DISCOURSE_SMTP_ADDRESS: <address>
      #DISCOURSE_SMTP_PORT: 587                        # (optional, default 587)
      DISCOURSE_SMTP_USER_NAME: <username>
      DISCOURSE_SMTP_PASSWORD: <password>
      #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
      ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
      #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
      ## The CDN address for this Discourse instance (configured to pull)
      ## see https://meta.discourse.org/t/14857 for details
      #DISCOURSE_CDN_URL: //discourse-cdn.example.com
    volumes:
      - volume:
          guest: /shared
      - volume:
          guest: /var/log
    ## Plugins go here
    hooks:
      after_code:
        - exec:
            cd: $home/plugins
            cmd:
    run:
