Recently added post migration causes bootstrap to fail
Just tried to upgrade a discourse instance and got the following error!
I, [2018-11-14T10:16:54.955290 #13]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
execution expired
/var/www/discourse/lib/final_destination.rb:385:in `safe_session'
/var/www/discourse/lib/final_destination.rb:336:in `safe_get'
/var/www/discourse/lib/final_destination.rb:108:in `get'
/var/www/discourse/lib/file_helper.rb:43:in `download'
/var/www/discourse/db/post_migrate/20181112013117_migrate_url_site_settings.rb:29:in `block (2 levels) in up'
/var/www/discourse/db/post_migrate/20181112013117_migrate_url_site_settings.rb:25:in `loop'
/var/www/discourse/db/post_migrate/20181112013117_migrate_url_site_settings.rb:25:in `block in up'
/var/www/discourse/db/post_migrate/20181112013117_migrate_url_site_settings.rb:14:in `each'
/var/www/discourse/db/post_migrate/20181112013117_migrate_url_site_settings.rb:14:in `up'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:817:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:7:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:6:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:798:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:797:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:414:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:796:in `migrate'
/var/www/discourse/lib/migration/safe_migrate.rb:27:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:977:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1292:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1343:in `block in ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/transaction.rb:230:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/transaction.rb:227:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1343:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1291:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1263:in `block in migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1262:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1262:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1210:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1363:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1210:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1036:in `up'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/migration.rb:1011:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/tasks/database_tasks.rb:172:in `migrate'
/var/www/discourse/lib/migration/safe_migrate.rb:50:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/railties/databases.rake:60:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.1/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
Net::OpenTimeout: execution expired
Tasks: TOP => db:migrate
I, [2018-11-14T10:18:04.151188 #13]  INFO -- : == 20181112013117 MigrateUrlSiteSettings: migrating ===========================
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 205 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
64c79116472b2923e011ea8ad736b7151cde65a31bfc156065d7a47570da6c5e
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
It seems like this migration is where things go wrong?
@dirkcuys Can you try again in about 15 minutes (our build needs to pass)?
https://github.com/discourse/discourse/commit/777364df01369d50a106e599bdddd76459499480
Same problem here, will try again in 15mins, thanks @zogstrip for the link :+1:
@tgxworld Do you have an ETA on the build pass?
It has passed, and you can see the commit at Commits · discourse/discourse · GitHub
Are you still seeing issues @Vaping_Community?
Yep, still seeing the same error :thinking:
This is the only error I can see
Bundle complete! 112 Gemfile dependencies, 202 gems now installed.
Gems in the group development were not installed.
Bundled gems are installed into ./vendor/bundle
I, [2018-11-14T11:44:40.341209 #14] INFO – : > cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’
rake aborted!
Failed to open TCP connection to vapingcommunity.co.uk:443 (Connection refused - connect(2) for “vapingcommunity.co.uk” port 443)
Isn’t it risky to depend on an external service (reached over the internet) in a migration? :worried:
@tgxworld I needed to forum back up, so I switched to the stable branch, if @Vaping_Community can’t test it for you later, give me a shout.
O you could have done a ./launcher start app to get your forum back up without having to switch branches
This is done in a post migration and I incorrectly assumed that the app will up when the migration is carried out. Also, the migration is meant to give up if it encounters the right set of errors but I missed out a couple of errors to rescue from.
I’m baking
https://github.com/discourse/discourse/commit/df111259fe7edd34e2d72d4484e4cc4f36e6b770
in our build process at the moment.
EDIT: Move not More xD
@Vaping_Community @dirkcuys You can try rebuilding now. Thank you for reporting :hugs:
Everything went smoothly, thank you very much :smile:
This topic was automatically closed after 4 days. New replies are no longer allowed.
