Qual a maneira recomendada de preservar alterações no server.en.yml?
Suppose i want to make some changes to some of the template strings in server.en.yml and I want them to persist across rebuilds (when I do ./launcher rebuild app). What is the recommended way to do that?
I can add a sed command in containers/app.yml int he run: section but that seems cumbersome. Is there another way?
You shouldn’t change the YML files. Use Customize › Text in the admin section instead.
Many thanks for the tip.
