Register to download
Register to download discussion revolves around restricting downloads/attachments to non-registered members. Webinsane initiated the conversation, seeking a solution to disable downloads for unregistered users. codinghorror suggested this feature could be supported in core, triggering a login prompt when clicking attachments. Webinsane aims to spark community growth by requiring registration to download CMS templates. tuananh mentioned a similar feature request, while Webinsane proposed alternative solutions, such as hiding download links or replacing attachments with login/signup prompts. Arta_S expressed interest in the feature, which codinghorror replied is partially available through the prevent anons from downloading files site setting, with more complex protection available through Secure Media Uploads.
We need to disable downloads/attachments (zipped files) to non-registered members. Searched but could not find a proper solution.
Great software and great community. We are setting up server so it can handle Discourse properly, but for now it is done deal the Discourse will be the platform for our new community.
4 curtidas
This is a good idea and sounds like something we might want to support in core as a flag to enable/disable download attachments unless you are a registered member.
I guess clicking the attachments with this flag set would trigger a login prompt?
Would also be safer from a bandwidth perspective, for sure.
7 curtidas
In our example we are giving CMS as open source on GitHub, but the actual CMS templates/HTML need forum registration to download. Something to spark new community growth :sunny:
I raise a feature similar to this where downloading attachment is used as an criteria in category permission aside create topic, view, etc… Someone replied that download is served by nginx directly now so its not possible.
Anything has changed?
I am not sure how direct download is problem if you replace attachment with login/signup.
I see that zip files are not supported in upload. Is this config setup or something that we will have to modify in order to attach zipped files? We could also hide links for download. Maybe that could be simpler solution for now.
Eu estava prestes a abrir o mesmo tópico. É uma ótima ideia ter esse recurso. Faz quase 6 anos que esse tópico foi criado. Isso já foi implementado? Obrigado.
Existe uma configuração do site impedir que anônimos baixem arquivos que você pode ativar para uma proteção leve. Para uma proteção mais robusta e muito mais complexa no lado do servidor, consulte Secure Uploads
6 curtidas
