I want to remove the following from the my discourse page:
- Related Post (post suggestions below the post)
- Pagination (When the post is opened…it shows in mobile view)
This is part of the ai plugin, you can disable the ai_embeddings_semantic_related_topics_enabled
setting.
Sorry, could you clarify this? Thanks!
That’s not pagination, Discourse doesn’t have that. That’s just a navigation control that tells you you are at Post #1 of 2 (in your example). Clicking it brings up a slider to move to a different part of the Topic.
Inspect the page in mobile view on desktop and remove it with some CSS if you like.
But this is a useful button, especially on longer Topics, so you should probably not hide as it will make it harder for your users to navigate.
While related topics are provided by the Discourse AI plugin as NateDhaliwal explained, there are also suggested topics, which show topics below a topic. There is a site setting Suggested topics
that allows you to configure the number of topics shown. You can change it to 0.
You can learn more about suggested topics at Understanding suggested topics logic
