Navigating to the Knowledge Explorer involved using the hamburger menu and clicking on Knowledge Explorer. I’m thinking the term Knowledge Explorer isn’t necessarily clear for every use case. For example, we use our Knowledge Explorer to surface How Tos, and it would be much simpler for us to be able to rename the Knowledge Explorer How Tos.
You should be able to customize this text like any other. Have you searched for “knowledge” on admin /customize /text?
Thank you! I didn’t know I could customize this text too. I
Discourse.
Yep, @pfaffman is right here. You can customize any localized text in Discourse this way ![]()
