The discussion revolves around the absence of a reply indicator when a single reply is directly beneath the post it responds to. WoodCutter4 reports the issue and shares a link to their forum post. codinghorror explains that this behavior is intentional to reduce visual noise and can be adjusted via site settings by searching for “suppress.” WoodCutter4 confirms this matches their observations. WoodCutter4 asks if the suppression only applies when other users’ posts are in between, but codinghorror clarifies that the quote itself serves as an indicator. Stephen adds that administrators can enable the link if needed, though it’s often considered unnecessary. WoodCutter4 thanks everyone for the clarification.
I saw some similar posts but I think this is unique. On the “maslow cnc forums”, I have been having this issue for quite some time. Here is the link to my documentation on what seems like an issue. I have tried using different browsers on laptop and iPhone. Can anyone offer any insight on this?
it is directly underneath the post it is replying to
… then metadata is suppressed in the interests of keeping the overall noise down, as it is generally clear from the existing verbal context that this is a reply.
Site owners can change this behavior in their site settings. Search for the word “suppress”.
Is there also a condition that requires posts from other users to be…in between..for lack of a better word? In my post#5 above I selected the text and pressed the “quote” button, which showed a reply to “codinghorror” but then it disappears after posting.
The typical reply indicator (screenshot below) is a link to the specific post being replied to; very helpful. But yeah, as it works now makes sense…I just didn’t put it together. Thanks.
Ask yourself whether you need a link to get all the way to the post directly above. If so, and the administrators of maslowcnc agree then they can turn it on. For most it’s unnecessary visual noise.
