In a discussion about requiring external gems in Discourse plugins, users explore how to include gems not in Discourse’s default Gemfile. kgish initiates the thread seeking guidance, and Falco points to an example plugin using plugin.rb to declare gems and their dependencies. kgish follows up asking about rake tasks, and zogstrip suggests using LOAD_PLUGINS=1 rake your:rake:task. Later, fzngagan shares a crash log while trying to use the oxford_dictionary gem, revealing dependency issues. merefield explains that all transitive dependencies must be manually declared in plugin.rb, calling it a “lengthy iterative process,” which Falco humorously renames a “lengthy recursive process.” fzngagan adds that require: false doesn’t work — the gem must be explicitly required. Luke_Clancy shares a practical workflow: use Ruby 2.6.5 locally, create a Gemfile, run bundle install, and copy dependencies into plugin.rb. Finally, JDoy99 reports a similar issue with the eth gem failing due to a missing forwardable dependency, despite manually installing the gem — highlighting that Discourse’s plugin gem loader doesn’t auto-resolve dependencies, requiring explicit declaration of all nested dependencies in plugin.rb.
/bin/bash -c "env RBENV_VERSION=2.6.2 /usr/local/Cellar/rbenv/1.1.2/libexec/rbenv exec ruby /Users/faiz/discenv/discourse/bin/rails server -b 0.0.0.0 -p 3000 -e development"
I, [2019-08-08T14:01:24.177008 #5867] INFO -- : Refreshing Gem list
Traceback (most recent call last):
30: from /Users/faiz/discenv/discourse/bin/unicorn:49:in `<main>'
29: from /Users/faiz/discenv/discourse/bin/unicorn:49:in `load'
28: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0/gems/unicorn-5.5.1/bin/unicorn:128:in `<top (required)>'
27: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:141:in `start'
26: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:794:in `build_app!'
25: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0/gems/unicorn-5.5.1/lib/unicorn.rb:54:in `block in builder'
24: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0/gems/unicorn-5.5.1/lib/unicorn.rb:54:in `eval'
23: from config.ru:1:in `<main>'
22: from config.ru:1:in `new'
21: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0/gems/rack-2.0.7/lib/rack/builder.rb:55:in `initialize'
20: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0/gems/rack-2.0.7/lib/rack/builder.rb:55:in `instance_eval'
19: from config.ru:7:in `block in <main>'
18: from config.ru:7:in `require'
17: from /Users/faiz/discenv/discourse/config/environment.rb:4:in `<top (required)>'
16: from /Users/faiz/discenv/discourse/config/environment.rb:4:in `require'
15: from /Users/faiz/discenv/discourse/config/application.rb:57:in `<top (required)>'
14: from /Users/faiz/discenv/discourse/config/application.rb:58:in `<module:Discourse>'
13: from /Users/faiz/discenv/discourse/config/application.rb:261:in `<class:Application>'
12: from lib/discourse.rb:168:in `activate_plugins!'
11: from lib/discourse.rb:168:in `each'
10: from lib/discourse.rb:171:in `block in activate_plugins!'
9: from /Users/faiz/discenv/discourse/lib/plugin/instance.rb:486:in `activate!'
8: from /Users/faiz/discenv/discourse/lib/plugin/instance.rb:486:in `instance_eval'
7: from /Users/faiz/discenv/discourse/plugins/discourse-dictionary/plugin.rb:7:in `activate!'
6: from /Users/faiz/discenv/discourse/lib/plugin/instance.rb:560:in `gem'
5: from /Users/faiz/discenv/discourse/lib/plugin_gem.rb:20:in `load'
4: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/2.6.0/rubygems/specification.rb:1420:in `activate'
3: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/2.6.0/rubygems/specification.rb:1438:in `activate_dependencies'
2: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/2.6.0/rubygems/specification.rb:1438:in `each'
1: from /Users/faiz/.rbenv/versions/2.6.2/lib/ruby/2.6.0/rubygems/specification.rb:1449:in `block in activate_dependencies'
/Users/faiz/.rbenv/versions/2.6.2/lib/ruby/2.6.0/rubygems/dependency.rb:311:in `to_specs': Could not find 'plissken' (~> 0.1.0) among 285 total gem(s) (Gem::MissingSpecError)
Checked in 'GEM_PATH=/Users/faiz/.rbenv/versions/2.6.2/lib/ruby/gems/2.6.0:/Users/faiz/.gem/ruby/2.6.0', execute `gem env` for more information
Process finished with exit code 1
Ich vermute, dass dies daran liegt, dass Discourse nicht in der Lage ist, eine Abhängigkeit zu installieren, die von der Gem selbst benötigt wird. Wie kann ich das beheben?
Update
Ok, ich habe es behoben. Die Abhängigkeit namens plissken musste separat erwähnt werden.
Warum ist das so?
Basierend auf meinen eigenen Erfahrungen, ein Update:
Ja, die Versionsnummer ist erforderlich.
Um diese Abhängigkeiten zu erhalten, installieren Sie Ruby 2.6.5 (die derzeit in Discourse verwendete Ruby-Version) auf Ihrem lokalen Rechner und erstellen Sie eine Gemfile-Datei mit den gewünschten Gems.
Hallo, ich weiß, das ist schon eine Weile her, aber ich versuche, das eth-Gem zu installieren, und es schlägt bei einer Abhängigkeit mit diesem Fehler fehl:
I, [2023-08-28T15:00:23.737246 #1] INFO -- : cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate'
rake aborted!
Gem::MissingSpecError: Could not find 'forwardable' (~> 1.3) among 231 total gem(s)
Checked in 'GEM_PATH=/var/www/discourse/vendor/bundle/ruby/3.2.0:/var/www/discourse/plugins/discourse-radiant-member/gems/3.2.2' at: /var/www/discourse/plugins/discourse-radiant-member/gems/3.2.2/specifications/eth-0.5.11.gemspec, execute `gem env` for more information
/var/www/discourse/lib/plugin_gem.rb:25:in `load'
/var/www/discourse/lib/plugin/instance.rb:825:in `gem'
/var/www/discourse/plugins/discourse-radiant-member/plugin.rb:10:in `activate!'
/var/www/discourse/lib/plugin/instance.rb:722:in `instance_eval'
/var/www/discourse/lib/plugin/instance.rb:722:in `activate!'
/var/www/discourse/lib/discourse.rb:346:in `block in activate_plugins!'
/var/www/discourse/lib/discourse.rb:343:in `each'
/var/www/discourse/lib/discourse.rb:343:in `activate_plugins!'
/var/www/discourse/config/application.rb:218:in `block in <class:Application>'
/var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
/var/www/discourse/config/application.rb:218:in `<class:Application>'
/var/www/discourse/config/application.rb:75:in `<module:Discourse>'
/var/www/discourse/config/application.rb:74:in `<top (required)>'
internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:37:in `require'
/var/www/discourse/Rakefile:7:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
Caused by:
Checked in 'GEM_PATH=/var/www/discourse/vendor/bundle/ruby/3.2.0:/var/www/discourse/plugins/discourse-radiant-member/gems/3.2.2' , execute `gem env` for more information
I, [2023-08-28T15:00:26.013232 #1] INFO -- : gem install eth -v 0.5.11 -i /var/www/discourse/plugins/discourse-radiant-member/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed eth-0.5.11
1 gem installed
I, [2023-08-28T15:00:26.014015 #1] INFO -- : Terminating async processes
I, [2023-08-28T15:00:26.014342 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2023-08-28T15:00:26.014700 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 111
2023-08-28 15:00:26.015 UTC [42] LOG: received fast shutdown request
111:signal-handler (1693234826) Received SIGTERM scheduling shutdown...
2023-08-28 15:00:26.027 UTC [42] LOG: aborting any active transactions
111:M 28 Aug 2023 15:00:26.030 # User requested shutdown...
111:M 28 Aug 2023 15:00:26.031 * Saving the final RDB snapshot before exiting.
2023-08-28 15:00:26.034 UTC [42] LOG: background worker "logical replication launcher" (PID 51) exited with exit code 1
2023-08-28 15:00:26.035 UTC [46] LOG: shutting down
111:M 28 Aug 2023 15:00:26.074 * DB saved on disk
111:M 28 Aug 2023 15:00:26.074 # Redis is now ready to exit, bye bye...
2023-08-28 15:00:26.087 UTC [42] LOG: database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1002 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
32dfbed48cf5bbb8f9a2d25b0d75388e296cd78ce7f56d37fb7a59c543888ad1
Ich habe die forwardable-Abhängigkeit angefordert, zusammen mit ein paar anderen nur für den Fall (die ich aus meiner Gemfile.lock habe), aber meine App kann einfach nicht neu aufgebaut werden, ohne diesen Fehler auszulösen. Irgendwelche Ideen?
