The user net_deamon is facing issues with specifying gem dependencies for a Discourse plugin, particularly when using a private repository like Bitbucket. Initially, they tried adding gem 'mini_magick', '~> 4.8' in plugin.rb, but encountered errors like gem does not exist and permission issues. They also attempted to install the gem via a custom command in the yml file, but the gem couldn’t be required in the code. sam clarified that using ~> is incorrect and a specific version like 1.4.0 must be used. The issue was traced to permissions, as the plugin directory wasn’t writable during the Docker build. pfaffman suggested chmod -r 777, but RGJ warned against this, recommending proper chown and chmod 755 instead. net_deamon confirmed that setting permissions to 755 resolved the issue. frank.manuel added that using a full version (e.g., 1.4.0) instead of a partial one (e.g., 1.4) is crucial for successful gem installation.
I did go through the suggesstions in following posts
So I tried 2 ways
Specifying in plugin.rb file
My plugin depends upon “mini_magick” for image resizing, so I specified it in plugin.rb
gem ‘mini_magick’, ‘~> 4.8’
But I get the following error
I, [2017-07-09T03:54:49.899941 #13] INFO – : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake db:migrate
ERROR: While executing gem … (Gem::Requirement::BadRequirementError)
Illformed requirement [“/root”]
I, [2017-07-09T03:54:54.692893 #13] INFO – : /root is not writable.
Bundler will use `/tmp/bundler/home/discourse’ as your home directory temporarily.
gem install mini_magick -v ~> 4.8 -i /var/www/discourse/plugins/discussbook-plugin/gems/2.4.1 --no-document --ignore-dependencies
You are specifying the gem mini_magick in /var/www/discourse/plugins/discussbook-plugin/plugin.rb, however it does not exist!
Specifying in yml file
As it was not working, I tried to add the gem install command in yml file custom commands
exec: gem install mini_magick -v 4.8.0
I get the following log(success) when it was being rebuilt
I, [2017-07-08T18:50:43.302333 #13] INFO – : Beginning of custom commands
I, [2017-07-08T18:50:43.302751 #13] INFO – : > gem install mini_magick -v 4.8.0
I, [2017-07-08T18:50:44.034391 #13] INFO – : Successfully installed mini_magick-4.8.0
1 gem installed
But when I try to require it in the route, I got the following error in error log
I can run the plugin locally… But in the server, the docker rebuild causes this issue.
Are you suggesting that I should enter inside docker, and change the permissions of folder to writable?
I will try that out, but if it would have been possible from plugin itself, it would be great.
Hi @sam, thanks for answer.
I tried this many times in different configurations, but it failed. Then I came to know real cause, though I do not know the solution
When I install the discourse-backups-to-dropbox plugin from github (plugin that you shared), the docker builds properly. But if I put it discourse-backups-to-dropbox in private repository like bitbucket, it throws the error. The error logs for the plugin are same as shared in first post ie
ERROR: While executing gem … (Errno::EACCES)
Permission denied @ dir_s_mkdir - /var/www/discourse/plugins/discourse-backups-to-dropbox/gems
I, [2017-07-10T18:18:41.229582 #15] INFO – : /root is not writable.
gem install public_suffix -v 2.0.5 -i /var/www/discourse/plugins/discourse-backups-to-dropbox/gems/2.4.1 --no-document --ignore-dependencies
You are specifying the gem public_suffix in /var/www/discourse/plugins/discourse-backups-to-dropbox/plugin.rb, however it does not exist!
I, [2017-07-10T18:18:41.230126 #15] INFO – : Terminating async processes
So I guess the problem lies in the my private repo configuration. But if the plugin(without any gem) gets installed properly from bitbucket, I do not know why would installing plugin with gem throw error. It should not matter whether the plugin is in open repository like github or in private repo like bitbucket.
My private repo config
exec: cd /var/www/discourse && sudo -u discourse bundle install --deployment --without test --without development
That is one hell of a scary advice.
I advise to figure out which user needs write permissions, and then chown it to that user, keeping the permissions at 0755.
