Hi,
I’ve accidentally deleted the wrong CSS and as a result lost all the customisations that I had made.
I tried to restore from backup, but the button is greyed out. Is there a way to get the CSS back?
Many thanks for your help.
Hi,
Have you looked at the Logs tabs in the Admin section? You should be able to recover it from the history ![]()
Thank you very much, solved! ![]()
