Is it possible to restrict the topic summary view to only the admin level (or higher trust users?)
Why would you want to restrict this? It is only a summary of what is in the thread anyway
3 לייקים
Simpler user experience. My audience is 50-65 year olds and I need to keep this as simple as possible.
The easiest way is to just hide this button for everyone:
.map.map-collapsed nav.buttons {
display: none;
6 לייקים
My audience is a bit older too - but then they don’t click on it, surely? It is not a requirement. Has someone specifically objected to it?
לייק 1
Yes. People get confused. Especially the non-technical ones.
I think your best option here is @Stranik’s suggestion above. It makes no sense to restrict access across the board.
2 לייקים
