Recuperar post.raw solo funciona justo después de crear el post
Hi there,
At the moment I am working on an extra PostMenuButton. Funny thing is that the Cooked post is always available but the Raw post is not!
Running discourse version [v2.3.0.beta8 +103]
<script type = "text/discourse-plugin" version = "0.1" >
  api.addPostMenuButton('trimetrack', attrs => {
    return {
      action: 'createTimeTracking',
      icon: 'calendar-alt',
      className: 'time-tracking',
      title: 'time_tracking',
      position: 'first'
  api.attachWidgetAction('post-menu', 'createTimeTracking', function() {
    const post = this.findAncestorModel();
    alert("Raw post: " + post.raw);
    alert("Cooked post: " + post.cooked);
  </script>
Steps to reproduce:
  1. Create theme component with code as shown above.
  2. Create a new post, do not refresh, click the calendar icon.
  3. See the alert pop-ups.
  4. Refresh the page. Click on the calendar button again for the same post.
  5. Now the post only has the cooked content available, raw content is not getting through.
I hope anyone can either spot my failure or confirm the bug :slight_smile:
This is by design, we prefer to keep our topic payload smaller so if you need raw you have to ask for it on-demand.
Otherwise we would be shipping data to all clients that they do not need the vast majority of the time.
Thanks for your reply! Now I can stop wasting time :slight_smile:
Ahh that makes so much sense!
Could you point me in the right direction to retrieve post data from javascript?
I had a sort of workaround to get the .json by retrieving the /t/raw/{topicid}/{postid}.json but that was really ugly and there must be a better way.
Yeah that is pretty much your only option.
Thank you. I will make my workaround less ugly and post it here when finished!
¿Esto sigue siendo cierto? Al editar una publicación, la solicitud es, por ejemplo, a /posts/13.json
¿Existe alguna API de JS para ello? ¿O alguna API de JS para realizar una solicitud autenticada?
@Mathijs_V ¿Podrías compartir tu código?
¡Gracias!
Así es como lo hice por el momento:
import {ajax} from "discourse/lib/ajax";
let post = this.findAncestorModel();
ajax(`/posts/${post.id}`, { type: "GET", cache: false }).then(
  (result) => {
    console.log(result.raw);
Tomado de aquí: discourse-checklist/assets/javascripts/discourse/initializers/checklist.js.es6 at a94022393c1fd290e492688041896d4392129052 · discourse/discourse-checklist · GitHub
