Routing Error uninitialized constant TestController
Hi i wrote a simple plugin just for education purpose. I need to get a json by calling http://localhost:4000/admin/plugins/test/list
url. I wrote the plugin.rb as
# name: test-plugin
# about: This is intended to be a test
# version: 1.0.0
# authors: Test_Author
    after_initialize do
    	module ::Test
    	    class Engine < ::Rails::Engine
    	      engine_name 'test'
    	      isolate_namespace Test
      	require_dependency 'application_controller'
     	class ::Test::TestController < ::ApplicationController
    	  	#This class will contain all the back end controller methods
    	    requires_plugin 'test-plugin'
    	    require_dependency 'admin_constraint'
    	    #this will return the JSON of users in the plugin store
    	    def list
        		render json: { name: "donut", description: "delicious!" }
    	Test::Engine.routes.draw do
    		get "/list" => "test#list", constraints: AdminConstraint.new
    	Discourse::Application.routes.prepend do
       		mount ::Test::Engine, at: "/test"
      	add_admin_route "test.title", "test"
      	Discourse::Application.routes.append do
       		get "/admin/plugins/test" => "admin/plugins#index"
       		get "/admin/plugins/test/list" => "test#list"
But when i call the url , it always return
Routing Error
Rails.root: /vagrant
Application Trace | Framework Trace | Full Trace
config/initializers/100-quiet_logger.rb:17:in `call_with_quiet_assets'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/missing_avatars.rb:21:in `call'
lib/middleware/turbo_dev.rb:33:in `call'
can someone please help. I’m just a newbie here.
Thank you all. I removed the engine and now it works.
# name: test-plugin
# about: This is intended to be a feature-rich plugin for opencollective-discourse integration
# version: 1.0.0
# authors: Sudaraka Jayathilaka
    after_initialize do
     	class ::TestController < ::ApplicationController
    	    def list
