Hi, there is no error trace at all but here is what I tried next:
I tried it again with a fresh installation of discourse.
Then I just added a new plugin folder with a plugib.rb:
# name: Disraptor
# about: A super simple plugin to demonstrate how plugins work
# version: 0.0.1
# authors: Awesome Plugin Developer
enabled_site_setting :disraptor_enabled
# load the engine
load File.expand_path('../lib/disraptor/engine.rb', __FILE__)
after_initialize do
Discourse::Application.routes.append do
mount ::Disraptor::Engine, at: "/disraptor"
engine.rb:
module Disraptor
class Engine < ::Rails::Engine
isolate_namespace Disraptor
routes.rb:
Disraptor::Engine.routes.draw do
root to: "site#showroute"
get "/test" => "site#showroute"
site_controller.rb:
module Disraptor
class SiteController < ::ApplicationController
requires_plugin 'Disraptor'
def showroute
render text: "test"
Rails.logger.info "test"
and a settings.yml:
plugins:
disraptor_enabled:
default: true
client: true
the code in the showroute method also never gets called.
this is the log-print when I access http://localhost:4000/disraptor/test.
At least I would expect the info-log print from the controller somewhere here.
Listening on 0.0.0.0:3000, CTRL+C to stop
D, [2016-04-27T10:25:14.024166 #1804] DEBUG -- :
D, [2016-04-27T10:25:14.032335 #1804] DEBUG -- :
I, [2016-04-27T10:25:14.033077 #1804] INFO -- : Started GET "/disraptor/test" for 10.0.2.2 at 2016-04-27 10:25:14 -0400
D, [2016-04-27T10:25:15.032232 #1804] DEBUG -- : ActiveRecord::SchemaMigration Load (2.5ms) SELECT "schema_migrations".* FROM "schema_migrations"
D, [2016-04-27T10:25:15.267561 #1804] DEBUG -- : Permalink Exists (2.7ms) SELECT 1 AS one FROM "permalinks" WHERE "permalinks"."url" = 'disraptor/test' LIMIT 1 [["url", "disraptor/test"]]
I, [2016-04-27T10:25:15.301483 #1804] INFO -- : Processing by Disraptor::SiteController#showroute as HTML
D, [2016-04-27T10:25:15.312852 #1804] DEBUG -- : User Load (3.0ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:25:15.564756 #1804] DEBUG -- : (2.5ms) SELECT "groups"."id", "groups"."name" FROM "groups" ORDER BY "groups"."name" ASC
D, [2016-04-27T10:25:15.593559 #1804] DEBUG -- : (6.5ms) SELECT categories.id FROM "categories" WHERE "categories"."read_restricted" = 't' [["read_restricted", true]]
D, [2016-04-27T10:25:15.606627 #1804] DEBUG -- : Category Load (6.0ms) SELECT categories.*, t.slug topic_slug FROM "categories" LEFT JOIN topics t on t.id = categories.topic_id WHERE (NOT categories.read_restricted or categories.id in (2,4)) ORDER BY "categories"."position" ASC
D, [2016-04-27T10:25:15.607889 #1804] DEBUG -- : UserVisit Load (3.6ms) SELECT "user_visits".* FROM "user_visits" WHERE "user_visits"."user_id" = 2 AND "user_visits"."visited_at" = '2016-04-27' LIMIT 1 [["user_id", 2], ["visited_at", Wed, 27 Apr 2016]]
D, [2016-04-27T10:25:15.665444 #1804] DEBUG -- : (8.4ms) SELECT "categories"."id" FROM "categories"
D, [2016-04-27T10:25:15.690818 #1804] DEBUG -- : (2.5ms) SELECT "category_users"."category_id", "category_users"."notification_level" FROM "category_users" WHERE "category_users"."user_id" = 2
D, [2016-04-27T10:25:15.706722 #1804] DEBUG -- : SQL (43.7ms) UPDATE "users" SET "last_seen_at" = '2016-04-27 14:25:15.363892' WHERE "users"."id" = 2 [["id", 2]]
D, [2016-04-27T10:25:15.708963 #1804] DEBUG -- : PostActionType Load (2.7ms) SELECT "post_action_types".* FROM "post_action_types" ORDER BY position asc
D, [2016-04-27T10:25:15.834216 #1804] DEBUG -- : (2.5ms) SELECT "translation_overrides"."translation_key", "translation_overrides"."value", "translation_overrides"."compiled_js" FROM "translation_overrides" WHERE "translation_overrides"."locale" = 'en' [["locale", :en]]
D, [2016-04-27T10:25:15.851177 #1804] DEBUG -- : PostActionType Load (2.8ms) SELECT "post_action_types".* FROM "post_action_types" WHERE "post_action_types"."name_key" IN ('inappropriate', 'spam', 'notify_moderators') ORDER BY position asc
D, [2016-04-27T10:25:15.873528 #1804] DEBUG -- : UserField Load (3.5ms) SELECT "user_fields".* FROM "user_fields"
D, [2016-04-27T10:25:15.920356 #1804] DEBUG -- : SiteCustomization Load (2.3ms) SELECT "site_customizations".* FROM "site_customizations" WHERE "site_customizations"."enabled" = 't' ORDER BY "site_customizations"."name" ASC [["enabled", true]]
D, [2016-04-27T10:25:15.959208 #1804] DEBUG -- : CACHE (0.0ms) SELECT "site_customizations".* FROM "site_customizations" WHERE "site_customizations"."enabled" = 't' ORDER BY "site_customizations"."name" ASC [["enabled", true]]
D, [2016-04-27T10:25:15.980698 #1804] DEBUG -- : Topic Load (2.6ms) SELECT "topics".* FROM "topics" WHERE ("topics"."deleted_at" IS NULL) AND "topics"."archetype" = 'banner' ORDER BY "topics"."id" ASC LIMIT 1 [["archetype", "banner"]]
D, [2016-04-27T10:25:16.044649 #1804] DEBUG -- : (2.8ms) SELECT COUNT(*) FROM "notifications" WHERE "notifications"."user_id" = 2 AND (read = false) [["user_id", 2]]
D, [2016-04-27T10:25:16.078315 #1804] DEBUG -- : UserStat Load (1.7ms) SELECT "user_stats".* FROM "user_stats" WHERE "user_stats"."user_id" = 2 LIMIT 1 [["user_id", 2]]
D, [2016-04-27T10:25:16.116261 #1804] DEBUG -- : UserOption Load (2.0ms) SELECT "user_options".* FROM "user_options" WHERE "user_options"."user_id" = 2 LIMIT 1 [["user_id", 2]]
D, [2016-04-27T10:25:16.157429 #1804] DEBUG -- : (2.7ms) SELECT "category_users"."category_id" FROM "category_users" WHERE "category_users"."user_id" = 2 AND "category_users"."notification_level" = 0 [["user_id", 2], ["notification_level", 0]]
D, [2016-04-27T10:25:16.179991 #1804] DEBUG -- : UserProfile Load (2.2ms) SELECT "user_profiles".* FROM "user_profiles" WHERE "user_profiles"."user_id" = 2 LIMIT 1 [["user_id", 2]]
D, [2016-04-27T10:25:16.217825 #1804] DEBUG -- : (2.6ms) SELECT COUNT(*) FROM "queued_posts" WHERE "queued_posts"."state" = 1 AND "queued_posts"."queue" = 'default' [["state", 1]]
D, [2016-04-27T10:25:16.224579 #1804] DEBUG -- : CACHE (0.0ms) SELECT COUNT(*) FROM "queued_posts" WHERE "queued_posts"."state" = 1 AND "queued_posts"."queue" = 'default' [["state", 1]]
I, [2016-04-27T10:25:16.277286 #1804] INFO -- : Rendered default/empty.html.erb within layouts/application (2.8ms)
D, [2016-04-27T10:25:16.299826 #1804] DEBUG -- : ColorScheme Load (2.0ms) SELECT "color_schemes".* FROM "color_schemes" WHERE "color_schemes"."versioned_id" IS NULL AND "color_schemes"."enabled" = 't' LIMIT 1 [["enabled", true]]
I, [2016-04-27T10:25:16.403547 #1804] INFO -- : Rendered layouts/_head.html.erb (110.8ms)
I, [2016-04-27T10:26:18.767477 #1804] INFO -- : Rendered common/_special_font_face.html.erb (62263.7ms)
D, [2016-04-27T10:26:18.780559 #1804] DEBUG -- : CACHE (0.0ms) SELECT "color_schemes".* FROM "color_schemes" WHERE "color_schemes"."versioned_id" IS NULL AND "color_schemes"."enabled" = 't' LIMIT 1 [["enabled", true]]
D, [2016-04-27T10:26:18.789636 #1804] DEBUG -- : (2.7ms) SELECT "categories"."updated_at" FROM "categories" WHERE (background_url IS NOT NULL and background_url != '') ORDER BY updated_at desc LIMIT 1
D, [2016-04-27T10:26:19.021500 #1804] DEBUG -- : CACHE (0.0ms) SELECT "color_schemes".* FROM "color_schemes" WHERE "color_schemes"."versioned_id" IS NULL AND "color_schemes"."enabled" = 't' LIMIT 1 [["enabled", true]]
D, [2016-04-27T10:26:19.031050 #1804] DEBUG -- : (2.2ms) SELECT "categories"."updated_at" FROM "categories" WHERE (background_url IS NOT NULL and background_url != '') ORDER BY updated_at desc LIMIT 1
D, [2016-04-27T10:26:19.130216 #1804] DEBUG -- : (3.2ms) SELECT "site_customizations"."stylesheet_baked" FROM "site_customizations" WHERE "site_customizations"."enabled" = 't' ORDER BY "site_customizations"."name" ASC [["enabled", true]]
I, [2016-04-27T10:26:19.138218 #1804] INFO -- : Rendered common/_discourse_stylesheet.html.erb (360.2ms)
D, [2016-04-27T10:26:42.960328 #1804] DEBUG -- : CACHE (0.0ms) SELECT "site_customizations".* FROM "site_customizations" WHERE "site_customizations"."enabled" = 't' ORDER BY "site_customizations"."name" ASC [["enabled", true]]
I, [2016-04-27T10:26:42.978818 #1804] INFO -- : Rendered application/_header.html.erb (1.1ms)
D, [2016-04-27T10:26:42.984612 #1804] DEBUG -- : CACHE (0.0ms) SELECT "site_customizations".* FROM "site_customizations" WHERE "site_customizations"."enabled" = 't' ORDER BY "site_customizations"."name" ASC [["enabled", true]]
I, [2016-04-27T10:26:43.180211 #1804] INFO -- : Rendered common/_discourse_javascript.html.erb (184.7ms)
D, [2016-04-27T10:26:43.185265 #1804] DEBUG -- : CACHE (0.0ms) SELECT "site_customizations".* FROM "site_customizations" WHERE "site_customizations"."enabled" = 't' ORDER BY "site_customizations"."name" ASC [["enabled", true]]
I, [2016-04-27T10:26:43.192504 #1804] INFO -- : Completed 200 OK in 87886ms (Views: 86907.2ms | ActiveRecord: 143.8ms)
D, [2016-04-27T10:26:43.329064 #1804] DEBUG -- :
D, [2016-04-27T10:26:43.329272 #1804] DEBUG -- :
I, [2016-04-27T10:26:43.329728 #1804] INFO -- : Started GET "/stylesheets/desktop.css?body=1" for 10.0.2.2 at 2016-04-27 10:26:43 -0400
I, [2016-04-27T10:26:43.926898 #1804] INFO -- : Processing by StylesheetsController#show as HTML
I, [2016-04-27T10:26:43.931376 #1804] INFO -- : Parameters: {"body"=>"1", "name"=>"desktop"}
D, [2016-04-27T10:26:43.937313 #1804] DEBUG -- : User Load (0.9ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:26:43.952901 #1804] DEBUG -- : (1.0ms) SELECT "stylesheet_cache"."created_at" FROM "stylesheet_cache" WHERE "stylesheet_cache"."target" = 'desktop' ORDER BY id desc [["target", "desktop"]]
I, [2016-04-27T10:26:43.962404 #1804] INFO -- : Sent file /vagrant/tmp/stylesheet-cache/desktop.css (0.5ms)
I, [2016-04-27T10:26:43.999774 #1804] INFO -- : Completed 200 OK in 64ms (ActiveRecord: 3.3ms)
D, [2016-04-27T10:26:44.007476 #1804] DEBUG -- : UserVisit Load (1.7ms) SELECT "user_visits".* FROM "user_visits" WHERE "user_visits"."user_id" = 2 AND "user_visits"."visited_at" = '2016-04-27' LIMIT 1 [["user_id", 2], ["visited_at", Wed, 27 Apr 2016]]
D, [2016-04-27T10:26:44.020635 #1804] DEBUG -- :
D, [2016-04-27T10:26:44.022744 #1804] DEBUG -- :
I, [2016-04-27T10:26:44.023114 #1804] INFO -- : Started GET "/stylesheets/admin.css?body=1" for 10.0.2.2 at 2016-04-27 10:26:44 -0400
D, [2016-04-27T10:26:44.208716 #1804] DEBUG -- : SQL (196.1ms) UPDATE "users" SET "last_seen_at" = '2016-04-27 14:26:43.942690' WHERE "users"."id" = 2 [["id", 2]]
I, [2016-04-27T10:26:44.284135 #1804] INFO -- : Processing by StylesheetsController#show as HTML
I, [2016-04-27T10:26:44.291731 #1804] INFO -- : Parameters: {"body"=>"1", "name"=>"admin"}
D, [2016-04-27T10:26:44.298228 #1804] DEBUG -- : User Load (0.7ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:26:44.305253 #1804] DEBUG -- : (0.5ms) SELECT "stylesheet_cache"."created_at" FROM "stylesheet_cache" WHERE "stylesheet_cache"."target" = 'admin' ORDER BY id desc [["target", "admin"]]
I, [2016-04-27T10:26:44.312916 #1804] INFO -- : Sent file /vagrant/tmp/stylesheet-cache/admin.css (0.3ms)
I, [2016-04-27T10:26:44.317918 #1804] INFO -- : Completed 200 OK in 21ms (ActiveRecord: 1.1ms)
D, [2016-04-27T10:27:13.706459 #1804] DEBUG -- :
D, [2016-04-27T10:27:13.707090 #1804] DEBUG -- :
I, [2016-04-27T10:27:13.707715 #1804] INFO -- : Started GET "/404-body?_=1461767230638" for 10.0.2.2 at 2016-04-27 10:27:13 -0400
I, [2016-04-27T10:27:13.914026 #1804] INFO -- : Processing by ExceptionsController#not_found_body as HTML
I, [2016-04-27T10:27:13.918441 #1804] INFO -- : Parameters: {"_"=>"1461767230638"}
D, [2016-04-27T10:27:13.924641 #1804] DEBUG -- : User Load (2.0ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:27:13.937039 #1804] DEBUG -- : (1.9ms) SELECT "categories"."topic_id" FROM "categories"
D, [2016-04-27T10:27:13.944662 #1804] DEBUG -- : (1.6ms) SELECT "categories"."id" FROM "categories" WHERE "categories"."read_restricted" = 'f' [["read_restricted", false]]
D, [2016-04-27T10:27:13.972539 #1804] DEBUG -- : SQL (7.8ms) SELECT .....
D, [2016-04-27T10:27:13.994738 #1804] DEBUG -- : Topic Load (3.8ms) SELECT "topics".* FROM "topics" WHERE ("topics"."deleted_at" IS NULL) AND ("topics"."id" NOT IN (1, 3, 2)) AND (topics.archetype <> 'private_message') AND "topics"."visible" = 't' AND (category_id IS NULL OR category_id IN (
SELECT c.id FROM categories c
WHERE NOT c.read_restricted)) ORDER BY created_at desc LIMIT 10 [["visible", true]]
D, [2016-04-27T10:27:14.043489 #1804] DEBUG -- : Category Load (2.1ms) SELECT "categories".* FROM "categories" WHERE "categories"."id" = 3 LIMIT 1 [["id", 3]]
D, [2016-04-27T10:27:14.053863 #1804] DEBUG -- : Category Load (1.7ms) SELECT "categories".* FROM "categories" WHERE "categories"."id" = 1 LIMIT 1 [["id", 1]]
I, [2016-04-27T10:27:14.058787 #1804] INFO -- : Rendered exceptions/not_found.html.erb (69.8ms)
I, [2016-04-27T10:27:14.065158 #1804] INFO -- : Rendered text template (0.0ms)
I, [2016-04-27T10:27:14.067440 #1804] INFO -- : Completed 200 OK in 145ms (Views: 4.3ms | ActiveRecord: 20.9ms)
D, [2016-04-27T10:27:14.078353 #1804] DEBUG -- :
D, [2016-04-27T10:27:14.078540 #1804] DEBUG -- :
I, [2016-04-27T10:27:14.078836 #1804] INFO -- : Started GET "/about/live_post_counts.json?_=1461767230639" for 10.0.2.2 at 2016-04-27 10:27:14 -0400
I, [2016-04-27T10:27:14.274221 #1804] INFO -- : Processing by AboutController#live_post_counts as JSON
I, [2016-04-27T10:27:14.280119 #1804] INFO -- : Parameters: {"_"=>"1461767230639"}
D, [2016-04-27T10:27:14.286324 #1804] DEBUG -- : User Load (1.9ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:27:14.300917 #1804] DEBUG -- : (6.9ms) SELECT "categories"."topic_id" FROM "categories"
D, [2016-04-27T10:27:14.323524 #1804] DEBUG -- : (4.0ms) SELECT COUNT(*) FROM "topics" WHERE ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = 't' AND (category_id IS NULL OR category_id IN (
WHERE NOT c.read_restricted)) AND ("topics"."id" NOT IN (1, 3, 2)) [["visible", true]]
D, [2016-04-27T10:27:14.334184 #1804] DEBUG -- : (2.1ms) SELECT SUM("topics"."posts_count") FROM "topics" WHERE ("topics"."deleted_at" IS NULL) AND (topics.archetype <> 'private_message') AND "topics"."visible" = 't' AND (category_id IS NULL OR category_id IN (
I, [2016-04-27T10:27:14.341678 #1804] INFO -- : Completed 200 OK in 58ms (Views: 0.3ms | ActiveRecord: 24.9ms)
D, [2016-04-27T10:27:15.248080 #1804] DEBUG -- : User Load (0.7ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:27:15.266296 #1804] DEBUG -- : (8.4ms) SELECT "groups"."id" FROM "groups"
D, [2016-04-27T10:27:15.275993 #1804] DEBUG -- : Delivering messages [{"global_id":-1,"message_id":-1,"channel":"/__status","data":{"/new":11,"/latest":14,"/unread/2":0,"/delete":0,"/recover":0,"/global/asset-version":1,"/site/banner":0,"/file-change":0,"/logout":0,"/site/read-only":0,"/flagged_counts":0,"/queue_counts":0,"/notification/2":1,"/categories":0,"/client_settings":0,"/notification-alert/2":0}}] to client 23844a809bf3427b8fa9af33723782b7 for user 2 (chunked)
D, [2016-04-27T10:27:40.276067 #1804] DEBUG -- : Delivering messages [] to client 23844a809bf3427b8fa9af33723782b7 for user 2 (chunked)
D, [2016-04-27T10:27:41.233650 #1804] DEBUG -- : User Load (0.8ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:27:41.239365 #1804] DEBUG -- : (0.5ms) SELECT "groups"."id" FROM "groups"
D, [2016-04-27T10:27:41.246622 #1804] DEBUG -- : Delivering messages [] to client 23844a809bf3427b8fa9af33723782b7 for user 2 (chunked)
D, [2016-04-27T10:28:06.246788 #1804] DEBUG -- : Delivering messages [] to client 23844a809bf3427b8fa9af33723782b7 for user 2 (chunked)
D, [2016-04-27T10:28:07.232273 #1804] DEBUG -- : User Load (0.5ms) SELECT "users".* FROM "users" WHERE "users"."auth_token" = 'ac478c77c48985c112e4f457c80dc3e9' LIMIT 1 [["auth_token", "ac478c77c48985c112e4f457c80dc3e9"]]
D, [2016-04-27T10:28:07.235803 #1804] DEBUG -- : (0.4ms) SELECT "groups"."id" FROM "groups"
D, [2016-04-27T10:28:07.240967 #1804] DEBUG -- : Delivering messages [] to client 23844a809bf3427b8fa9af33723782b7 for user 2 (chunked)
