3 Container für 3 Domains in einer Installation mit SSL betreiben
after tweaking with lets encrypt several days ,here is for anyone who interested in running multible
1 purpose
assume you have a domain like this ,and you want 3 forums
bbs.antivte.com
cp.antivte.com
ytb.antivte.com
2.discourse container
2.1 prepare
you should have 3 app.yml for your different forums,named as
bbs.yml,cp.yml,ytb.yml as you like .
content should be like this
**pls note we do use a unix socket to connect outside nginx and backend discouse container instead listen 80 443 port and rm ssl configure for backend container too **
pls do note here we only got a container for each forum ,not separate data and web container for each forum.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
#  - "templates/web.ssl.template.yml"
#  - "templates/web.letsencrypt.ssl.template.yml"
  - "templates/web.socketed.template.yml"  # <-- Added
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
**#expose:**
**#  - "8080:80"   # http**
**#  - "8443:443" # https**
params:
  db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 4
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: bbs.antivte.com
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'techempower@163.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: postmaster@mail.antivte.com
  DISCOURSE_SMTP_PASSWORD: "67c9458eb7a6ff11b4db70f097b1b5c3-f7910792-0e7dbcc9"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: techempower@163.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
volumes:
  - volume:
      **host: /var/discourse/shared/bbs**
      guest: /shared
  - volume:
      **host: /var/discourse/shared/bbs/log/var-log**
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/procourse/procourse-installer
run:
2.2 setup
have a setup shell like this
#!/usr/bin/env bash
./launcher bootstrap bbs
./launcher bootstrap test
./launcher bootstrap cp
./launcher bootstrap ytb
./launcher start bbs
./launcher  start test
./launcher  start  cp
./launcher  start  ytb
and if you ever have use this script,already run each container once,if you edit any content of app.yml,you should use to have container take effect.
./launcher rebuild bbs
2.3 checup
you will see 3 container running successfully and check unix socket if it is ok
root@docker-s-1vcpu-2gb-sgp1-01:~# docker ps
CONTAINER ID        IMAGE                 COMMAND             CREATED             STATUS              PORTS               NAMES
9702f94ea9b4        local_discourse/bbs   "/sbin/boot"        9 hours ago         Up 9 hours                              bbs
dc13c303c38e        local_discourse/cp    "/sbin/boot"        9 hours ago         Up 9 hours                              cp
dafa592ee16f        local_discourse/ytb   "/sbin/boot"        9 hours ago         Up 9 hours                              ytb
root@docker-s-1vcpu-2gb-sgp1-01:~#  curl --unix-socket /var/discourse/shared/bbs/nginx.http.sock http:/images/json
<!DOCTYPE html>
<html lang="zh-CN">
<head>
  <meta charset="utf-8">
  <title>血栓之家</title>
3 outside nginx
do install nginx/openresty on your server and make a nginx.conf in any directory you like, directory only affect your nginx running command, nginx.conf content is like this:
here i got a cloudflare cert and key and put it in the host directory as this
3.1 nginx.conf
    ssl_certificate      /var/discourse/shared/ssl/antivte.com.cert.pem;
    ssl_certificate_key  /var/discourse/shared/ssl/antivte.com.key.pem;
in future i wil give you how to use lets encrypt automatic cert and key in the outside nginx.
events {
  worker_connections 1024;
http {
  # The "auto_ssl" shared dict should be defined with enough storage space to
  # hold your certificate data. 1MB of storage holds certificates for
  # approximately 100 separate domains.
  lua_shared_dict auto_ssl 1m;
  # The "auto_ssl_settings" shared dict is used to temporarily store various settings
  # like the secret used by the hook server on port 8999. Do not change or
  # omit it.
  lua_shared_dict auto_ssl_settings 64k;
  # A DNS resolver must be defined for OCSP stapling to function.
  # This example uses Google's DNS server. You may want to use your system's
  # default DNS servers, which can be found in /etc/resolv.conf. If your network
  # is not IPv6 compatible, you may wish to disable IPv6 results by using the
  # "ipv6=off" flag (like "resolver 8.8.8.8 ipv6=off").
  resolver 8.8.8.8;
server {
    listen 80; listen [::]:80;
    server_name bbs.antivte.com;  # <-- change this
    return 301 https://$host$request_uri;
server {
    listen 443 ssl http2;  listen [::]:443 ssl http2;
#    ssl_dhparam          /var/discourse/shared/standalone/ssl/dhparams.pem;
    ssl_session_tickets off;
    ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:ECDHE-RSA-DES-CBC3-SHA:ECDHE-ECDSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA;
    http2_idle_timeout 5m; # up from 3m default
    location / {
        proxy_pass http://unix:/var/discourse/shared/bbs/nginx.http.sock;
        proxy_set_header Host $http_host;
        proxy_http_version 1.1;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto https;
        proxy_set_header X-Real-IP $remote_addr;
server {
    server_name cp.antivte.com;  # <-- change this
server {
    location / {
        proxy_pass http://unix:/var/discourse/shared/cp/nginx.http.sock;
server {
    server_name ytb.antivte.com;  # <-- change this
server {
    location / {
        proxy_pass http://unix:/var/discourse/shared/ytb/nginx.http.sock;
3.2 nginx start
go to the directory where you place your nginx.conf,run this one
 nginx -p `pwd`/ -c nginx.conf
4. you will get what you want then
woola
This seems to be a more complicated version of the already available discourse multisite. I wonder what advantage it provides to run three separate containers all racing for same resources instead of running one (or two in case separate web+data) ??
that`s all buget thing.and you can think this as a pre stage when you run prototype testing your customers and marketing .
Even in budgeting phase, I’d think multisite will be a much more simpeler and practical implementation. That way, I have less things to worry about configuration wise and more time to dedicate towards client/customer requirements.
all of this is dued to i want to do test and production over my solo server,if 80 443 of host is taken ,i do not have any other ways to realize all this
Thanks heaps for sharing, but I feel this need tons more detail before it becomes a howto, recategorizing.
