사이트 1을 성공적으로 설치하고 한 달 이상 운영해 왔습니다. 오늘 https://meta.discourse.org/t/running-other-websites-on-the-same-machine-as-discourse/17247에 있는 안내에 따라, 첫 번째 Discourse 설정을 수정하고 호스트 머신에 외부 nginx를 설치한 뒤 첫 번째 Discourse를 다시 빌드했습니다.
1번 사이트 app.yml
root@docker-s-1vcpu-2gb-sgp1-01:~# cat /var/bbs-antivte-discourse/containers/app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
# - "templates/web.ssl.template.yml"
# - "templates/web.letsencrypt.ssl.template.yml"
- "templates/web.socketed.template.yml" # <-- Added
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
#expose:
# - "80:80" # http
# - "443:443" # https
params:
db_shared_buffers: "256MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 4
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: bbs.antivte.com
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'techempower@163.com'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: postmaster@mail.antivte.com
DISCOURSE_SMTP_PASSWORD: "67c9458eb7a6ff11b4db70f097b1b5c3-f7910792"
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
LETSENCRYPT_ACCOUNT_EMAIL: techempower@163.com
## The http or https CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
volumes:
- volume:
host: /var/bbs-antivte-discourse/shared/standalone
guest: /shared
- volume:
host: /var/bbs-antivte-discourse/shared/standalone/log/var-log
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone https://github.com/discourse/discourse-knowledge-explorer
- git clone https://github.com/discourse/discourse-spoiler-alert.git
- git clone https://github.com/procourse/procourse-static-pages
run:
그리고 두 번째 사이트 설치를 위해 소스 코드를 다른 디렉토리로 git clone하고, 첫 번째로 수정한 app.yml을 복사한 뒤 두 번째 사이트를 위해 해당 파일의 도메인과 클론 디렉토리 이름만 수정했습니다. 그런 다음 https://github.com/discourse/discourse/blob/master/docs/INSTALL-cloud.md를 실행했습니다.
./discourse-setup
아래의 힌트 때문에 혼란스럽고, 두 사이트용 nginx 설정 파일이 각각 다릅니다.
1번 사이트 nginx 설정
root@docker-s-1vcpu-2gb-sgp1-01:~# cat /var/website/conf/conf.d/ytb.antivte.com
server {
listen 80; listen [::]:80;
server_name ytb.antivte.com; # <-- change this
return 301 https://$host$request_uri;
server {
listen 443 ssl http2; listen [::]:443 ssl http2;
# ssl on;
ssl_certificate /var/ytb-antivte-discourse/shared/standalone/ssl/ssl.crt;
ssl_certificate_key /var/ytb-antivte-discourse/shared/standalone/ssl/ssl.key;
ssl_dhparam /var/ytb-antivte-discourse/shared/standalone/ssl/dhparams.pem;
ssl_session_tickets off;
ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:ECDHE-RSA-DES-CBC3-SHA:ECDHE-ECDSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA;
http2_idle_timeout 5m; # up from 3m default
location / {
proxy_pass http://unix:/var/ytb-antivte-discourse/shared/standalone/nginx.http.sock:;
proxy_set_header Host $http_host;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Real-IP $remote_addr;
2번 사이트 nginx 설정
server {
server_name bbs.antivte.com; # <-- change this
server {
# ssl on;
ssl_certificate /var/bbs-antivte-discourse/shared/standalone/ssl/bbs.antivte.com.cer;
ssl_certificate_key /var/bbs-antivte-discourse/shared/standalone/ssl/bbs.antivte.com.key;
ssl_dhparam /var/bbs-antivte-discourse/shared/standalone/ssl/dhparams.pem;
location / {
proxy_pass http://unix:/var/bbs-antivte-discourse/shared/standalone/nginx.http.sock:;
그리고
/var/ytb-antivte-discourse/discourse-setup
Port 80 appears to already be in use.
This will show you what command is using port 80
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
nginx 4255 root 6u IPv4 22842780 0t0 TCP *:http (LISTEN)
nginx 4255 root 7u IPv6 22842781 0t0 TCP *:http (LISTEN)
nginx 4256 nobody 6u IPv4 22842780 0t0 TCP *:http (LISTEN)
nginx 4256 nobody 7u IPv6 22842781 0t0 TCP *:http (LISTEN)
If you are trying to run Discourse simultaneously with another web
server like Apache or nginx, you will need to bind to a different port
See https://meta.discourse.org/t/17247
If you are reconfiguring an already-configured Discourse, use
./launcher stop app
to stop Discourse before you reconfigure it and try again.
