Problema na página de configuração de backup do S3 Bucket
Hi, i have a problem, i dont see option to insert Access Key and secret key for AWS.
any suggestion?
Version Discourse
Installed### [v2.3.0.beta4 +1]
Search for S3?
It’s possible to override those settings with environment variables in the app.yml file. Did you install yourself?
this is my app.yml, i reinstall discourse in small instance in AWS and restore the lastest backup, after this look in my admin the first image (sorry my english)
should i need install some plugins o make configuracion?
   ## this is the all-in-one, standalone Discourse Docker container template
    ## After making changes to this file, you MUST rebuild
    ## BE *VERY* CAREFUL WHEN EDITING!
    ## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
    ## visit http://www.yamllint.com/ to validate this file as needed
    templates:
      - "templates/web.ssl.template.yml"
      - "templates/web.letsencrypt.ssl.template.yml"
    ## which TCP/IP ports should this container expose?
    ## If you want Discourse to share a port with another webserver like Apache or nginx,
    ## see https://meta.discourse.org/t/17247 for details
    expose:
      - "80:80"   # http
      - "443:443" # https
    params:
      #db_shared_buffers: "256MB"
      #db_work_mem: "40MB"
      #version: tests-passed
    env:
      LANG: en_US.UTF-8
      #UNICORN_WORKERS: 3
      ## Required. Discourse will not work with a bare IP number.
      DISCOURSE_HOSTNAME: xxxx.summasolutions.net
      ## Uncomment if you want the container to be started with the same
      ## hostname (-h option) as specified above (default "$hostname-$config")
      #DOCKER_USE_HOSTNAME: true
      DISCOURSE_DEVELOPER_EMAILS: 'xxx@summasolutions.net'
      ## TODO: The SMTP mail server used to validate new accounts and send notifications
      # SMTP ADDRESS, username, and password are required
      # WARNING the char '#' in SMTP password can cause problems!
      DISCOURSE_SMTP_ADDRESS: smtp.gmail.com
      DISCOURSE_SMTP_PORT: 587
      DISCOURSE_SMTP_USER_NAME: xxxxx@summasolutions.net
      DISCOURSE_SMTP_PASSWORD: "xxxxxxx"
      #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
      ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
      LETSENCRYPT_ACCOUNT_EMAIL: xxxx@summasolutions.net
      ## The http or https CDN address for this Discourse instance (configured to pull)
      ## see https://meta.discourse.org/t/14857 for details
    volumes:
      - volume:
          guest: /shared
      - volume:
          guest: /var/log
    ## Plugins go here
    hooks:
      after_code:
        - exec:
            cd: $home/plugins
            cmd:
              - git clone https://github.com/angusmcleod/discourse-custom-wizard.git
    run:
Did you filter the settings by “s3”? /admin/site_settings/category/all_results?filter=s3
The settings you are looking for aren’t in the “Backups” section of settings.
Perfect! this is my solution. Thanks you guys.
